Old 06-06-2020, 02:24 PM   #1
sst7250
sst7250's Avatar
Liked 45 Times in 32 Posts
Default Re: Do these stop numbers sound right?
Originally Posted by StompNDump View Post
One thing that I believe was an issue is the tight converter. While running an all out 1/8 mile race and launching at 4200 the converter was flat and seemed lazy. We upped the launch to 4600 and 4800 and the date looked much much better as far as the curve. So I am thinking with the RPM of 4100 on the stop it may be slightly below where I need to be while on the stop. Maybe an increase to 4400 will be where I need to be.
Well when it comes off the stop and its completely open you will have your answer. It will hit the stall speed and you can see how long it hands there. If you have some sort of logging ability, playback tach, Biondo 450 or similar or grid. Its certainly a big part of making things happy and getting the most you can.
sst7250 is offline   Reply With Quote
Old 06-05-2020, 10:23 PM   #2
Marc
Marc's Avatar
Liked 10 Times in 2 Posts
Actually the car has run 8.40 and an 8.37, this has been done with me at the end of last year in good air. This past weekend while running an 1/8 mile race it was dialed 5.45 all weekend long in the heat of Texas.
How did the car handle running all out? I also have a C5 Davis car, but it's the full size heavier body and I've been wanting to try some bracket racing off the stop. I heard with these cars you have to make some suspension/4 link adjustments to calm the launch.
Marc is offline   Reply With Quote
