Old 06-15-2020, 04:33 PM   #11
StompNDump
Default Re: NHRA Tech Cards
Just curious with the new online tech cards, since this will be my first time filling one out for S/G and S/ST. Do you have to check every single box on the tech card such as the ones that says, throttle, fire extinguisher, roll bars, roll cage, tires etc. ? These seem like obvious things a car would have but since im new to this I am confused. Dont wanna F it up.
StompNDump is offline   Reply With Quote
Old 06-15-2020, 06:26 PM   #12
ray4604
Just check the boxes you used to address when you filled out your card at the track. Then you will enter your serial numbers and expiration dates.
Ray Todd 4604 S/ST
ray4604 is offline   Reply With Quote
Old 06-15-2020, 09:42 PM   #13
StompNDump
I have never filled one out before. This will be my first time.
Old 06-16-2020, 07:57 AM   #14
Keith 944
Keith 944's Avatar
If you have a throttle then check it (Doesn’t everyone)
Same with bar or cage. Check One or the other Check all that applies if there is a question it won’t be accepted then you can double check and Try to send Again
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 06-16-2020, 11:00 AM   #15
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
I typically only address items with SFI numbers/dates and safety equipment.
S/ST 51
S/C 53
Old 06-17-2020, 07:34 AM   #16
Regan Wilson
Regan Wilson's Avatar
Liked 134 Times in 70 Posts
When I filled out the one for Tulsa. I filled out what I normally would. I punched in the Flexplate, Flexplate Shield etc. It made me go back to Flywheel stuff. Anything that didn't apply I just put in N/A.
Regan Wilson is offline   Reply With Quote
