Old 12-05-2019, 06:11 PM   #11
Crew Chief
Liked 10 Times in 6 Posts
Default Re: NHRA 2020 Rule Amendment SS Intakes???
As it was just explained to me, the new rule applies to those who have an angled spacer plate being used to replace material that has been cut off at an angle on the intake side of the head. They will also be looking for the OEM angle between the intake side of the head and the block side of the head. That is what the +/- 2 degree allowance is about.
Crew Chief is offline   Reply With Quote
Old 12-05-2019, 09:00 PM   #12
James L Miller
Liked 25 Times in 16 Posts
" External modifications prohibited except for the following, intake side of head may be +/- 2 degrees from OEM angle between combustion chamber surface to intake flange surface, may not be cut into any part of valve-cover fastener holes (except for SS/AH). Intake manifold fastener holes must remain unaltered in their original location. Only OEM intake fastener holes are permitted, any additional fastener holes are prohibited. Spacer plates between intake manifold and cylinder head prohibited. Valve-cover fastener holes must remain unaltered and in their original location."
So, does the angle rule get exempted for the SS/AH cars, or is that just for the "valve-cover fastener holes"? It's not entirely clear to me for those cars. Since it is one long, run-on sentence, the exemption would seem to apply to the whole sentence and SS/AH.
Mopar 2 Ya!
Old 12-05-2019, 09:41 PM   #13
fredjohnston
Liked 55 Times in 14 Posts
Cool Re: NHRA 2020 Rule Amendment SS Intakes???
I maybe wrong but haven't the big block Mopar stocker guys been doing this since the Edelbrock head was allowed?
fredjohnston is offline   Reply With Quote
Old 12-06-2019, 07:27 AM   #14
Bryan Worner
Liked 525 Times in 84 Posts
The intake manifold fastener hole lines have been deleted.
Bryan Worner is offline   Reply With Quote
Old 12-06-2019, 07:38 AM   #15
Liked 10,714 Times in 2,230 Posts
No spacer plates on my Edelbrock heads, paper gaskets and valley pan.
Old 12-07-2019, 03:55 PM   #16
Bryan Worner
Was just looking at the new NHRA 2020 Rule Book amendment prohibiting spacers between the intake and the cylinder head.
They already allow sheet metal intakes and also two piece intake manifolds split in the middle in the class so what is the difference in having a spacer between the intake and cylinder head?
This will effect many cars including Mopar 383 with Chevy intakes, Ford FE with 351C intakes and AMC with Mopar intakes running spacers to fit these intakes.
Mopar 383’s with Chevy intakes???? Shouldn’t Mopars run Mopar intakes? Shouldn’t Fords run Ford intakes? How many Chevys run Mopar or Ford intakes? Doesn’t Edelbrock make intakes for Ford and Mopar??? In Super Stock, isn’t the engine combination supposed to match the make of the car? If it didn’t before, I guess it does now, huh!!!
Old 12-07-2019, 04:05 PM   #17
james schaechter
Liked 1,432 Times in 299 Posts
Why would that matter when sheet metal fab intakes are legal?
James Schaechter 3163 STK
Old 12-07-2019, 04:35 PM   #18
Lee Valentine
Liked 319 Times in 68 Posts
Any intake manifold,don't screw with the intake surface of the head is how I understand it. Years ago when John Gunn was torn down NHRA wanted to look at his manifold and he told them no I'm allowed any intake and locked it in the trunk. He said you're not going to look at it and tell all your friends,he got the record and never showed the inside of the manifold.
Lee Valentine 1661 STK
Old 12-07-2019, 05:29 PM   #19
Jeff Niceswanger
Liked 1,032 Times in 368 Posts
I don't think any racing style aftermarket manifolds were made for Cadillacs. Ken Sharp come to mind.
Jeff Niceswanger 3740 SS
Old 12-07-2019, 06:03 PM   #20
jmcarter
jmcarter's Avatar
Liked 3,181 Times in 972 Posts
...or Bob Dennis.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
