11-26-2019, 02:03 PM | #11 |
Re: Dedenbear Lightning Plus Delay Box
I went back and looked at my box and im curious, why wont the SLE work with STOP A still being utilized for TS and STOP B for shift? Since the SLE's cycle is completed at Transbreak termination.
11-26-2019, 02:08 PM | #12 | |
Liked 432 Times in 225 Posts
That's actually what I do on my dragster, but it's mechanically injected and the car goes to dead idle on the throttle stop. There are other people doing it, but it's not a traditional setup.
S/ST 51 S/C 53 |
11-26-2019, 02:15 PM | #13 |
I am using an APD Max Speed Carb
11-26-2019, 02:44 PM | #14 |
I don't see how you could use a single delay box output to perform both functions, in that case.
Generally speaking, the SLE will be set to hold the engine at idle or near it. Throttle stop RPM is usually going to be 3700-4700 RPM. That STOPA output is either ON or OFF. How do the connected devices know which function is being commanded at what time?
S/ST 51 S/C 53 |
11-26-2019, 04:17 PM | #15 |
Thats what I was trying to figure out, I didnt say it couldnt be done or it could.
11-26-2019, 09:45 PM | #16 | |
Liked 18 Times in 12 Posts
I used it years ago with a separate delay box before I got the Dedenbear Lightning Plus. Glad I hung on to it.
Drew Wonderly SST 159 |
11-26-2019, 09:56 PM | #17 | |
I probably need to mess with it some more. I wonder if the break is not engaging fast enough and its just used to my slow foot LOL or as you say I may need a little more pump pressure (a few more RPM) in the stage position.
