#11 | |
Stockers are supposed to look, well, you know.... STOCK!
#12 |
Liked 47 Times in 6 Posts
LOL What?
Erik Jones |
#13 |
Liked 70 Times in 31 Posts
This is at the top of my list by far. I was closer than I liked to being a victim of this.
Darrel Goheen 785-623-7021 Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427 Tehnician for JustAnswer.com |
#14 |
I'm honestly slow.
#15 | |
Liked 62 Times in 29 Posts
But Stock, narrowing the rear, what does it gain? Still have to run a 9" tire, pulling them in an inch, what purpose does it serve? Not asking for a friend, asking to learn. I have worked on Stockers and been around them quite a bit, not seeing what performance advantage a narrower rear is going to serve. Now start looking at other areas where lots of people are "cheating", that is a whole 'nother story! |
#16 |
Liked 564 Times in 66 Posts
#17 |
Liked 511 Times in 122 Posts
Housing width ...
let’s see makes a vehicle that cannot accept a 9” tire a workable combination Allows car to be lowered in cases Allows less rotating mass as axles are shorter And the big one > it’s a f$&@king rule dip****s you don’t get to pick which ones to follow Jesus ... really hoping they get handle on the BS ![]()
Jack McCarthy 3609 STK "the Captain" |
#18 |
Liked 653 Times in 89 Posts
Joey my throttle body is so big on my CJ i don’t think if it were bigger it would help. Now putting one of those (big) custom made California throttle bodys that look like a factory GM one is worth about .10-.12 on a ss or so I’m told.
Captain your right let get back to company correct rear ends. While we’re righting wrongs let’s take away all those three speed to those guys that never had three speed factory equipped cars.
Charley Downing 3548 STK |
#19 |
Okay, Mr. "cm". You asked and I'll tell you.
BTW, this rule has been quite clear for 40 years now. Some guy comes along and decided he doesn't like, for whatever reason. He puts a narrowed housing in his car, which can be seen from 50 feet away.. Tech ( or lack thereof) doesn't notice it, or doesn't want to crawl around underneath with a tape measure. He doesn't have the exact factory width spec readily available to him, to be able to disqualify anybody. Next guy sees the obvious and decides he'll do it too. A half a dozen follow suit. A guy like Capt. Jack comes along and points it out. The half dozen offenders jump up and down and say, C'mon, what difference does it make ? NHRA says we don't care ,if you guys don't. Next thing you know, you're another step closer to Super Stock. Maybe you weren't around then , Mr. "cm". Stock was forced into Super Stock once already. Some of us don't want to see it happen again. Don't make it any easier for them.
#20 |
Charles ... first we are talking about enforcing current rules not 2/3 speed current rule
Second if you are referring to me a 60 (57-61) Chevy came equipped with a turbo glide which is a 3 speed (two planetary and direct drive) so my car is correctly equipped and yes I’d like to return other guys to two speeds but that’s irrelevant on this thread. I know your young but you can google turbo glide or ask your daddy ![]() Thanks for playing ![]()
