#11 |
Liked 7 Times in 5 Posts
Yes we have grounds running from both cylinder heads to the frame this setup was happy last year with a milder engine, and we like e85 for a number of reasons but i'm wondering about this fuel becuase it just happens to be the only real variable in this equation everything else was happy at the end of last season. unless its a internal issue with the engine. we did have a loose ground a week or so ago when we initially started the motor that caused some trouble but we found it and fixed it i'm wondering if that could have damaged the ignition box.
#12 |
Liked 1,943 Times in 584 Posts
Surging is most likely a fuel or carb issue. If it’s popping and sputtering then ignition would be suspect. Could be an issue with your accelerator pump. What carb?
Mike Pearson 2485 SS |
#13 |
Its 950qft convertered to e85 by mark sullens.
#14 |
and maybe a surge isn't the right word it would pop or just act like it wanted to die fall on its face comeback to life and repeat.
#15 |
Liked 182 Times in 61 Posts
If the carb. was set up for e-85 then it has richer jets for alcohol than straight racing fuel.May not be problem,still sounds electrical.Are connectors crimped or soldered? Plus box could have taken a hit with the bad ground.
#16 |
there all soldered. the only crimp would be the weather pack connector at the coil i guess that could be it.
#17 |
Liked 320 Times in 102 Posts
Just a heads up.......
About 40 years ago I had a similar problem with my MSD-7AL.. Race car would idle and take a throttle snap fine... Put it in gear and all was OK... When we went to drive the car it would stumble almost to the point of killing the engine.. Drove me crazy and I almost rebuilt that car from the ground up.. I found that the problem was a high resistance connection in the power circuit to the MSD.. It would light a test light.. MSD ignitions, depending on load such as large plug gaps, suppression plug wires and add to that the engine load of trying to accelerate, can draw up to 15 amps.. The higher the load the more the draw.. The MSD will stop firing, the load is reduced, then start working again.. Using a test light is useless to track this down and you need a Volt-Ohm meter to check the resistance in all of your power and ground connections.. I spent a lot of time tracking this down on our 350 Super Stock engine.. I hope that this helps
#18 |
BOB
Thats very helpful, what would you consider an acceptable ohm reading for a power and ground wire. i did check voltage at the box and its the same as battery voltage but i didn't ohm the power wire or the ground. however i will say we've had 2 other motors in this car before and this one was in in september of last year but couldn't keep head gaskets in. but the half pass and couple hub dyno pulls it made didn't display this issue which really makes me think the box took a hit and or there is a fuel issue but our 7al2 is 22 years old so we decided to go ahead and upgrade and its getting a grid system this weekend with a new hvh 2 coil and we will go from that point. |
#19 |
The ohm reading that I would be shooting for is zero...
I'm an old school guy... ALL of my electrical connections are crimped and soldered.. Do not use the crimp only, insulated type of butt and ring type connectors. The crimp is the mechanical connection and after crimping the connection should be tested by trying to pull it apart.. If the mechanical connection is OK then it is OK to finish the electrical connection by soldering.... Finish it off with the glue inserted shrink tubing and you have pretty much a lifetime, trouble free electrical connection..
