Old 02-04-2019, 01:45 PM   #1
jlundy
Default Want to run 9.90
First post..........
I would like to run SG in some Div 7 races but mostly run Super Pro @ 9.90 in local bracket races on the West Coast.
I'm new to all the delay box, throttle stop stuff plus I'm running a 3 speed transmission. I've installed a Pro Cube delay with 1 timer and I have a 2 stage ACD throttle stop, SLE and down track ET controller capable. Also a PPP Air shifter.
I being told I can't shift on RPM (using my separate 2shift RPM switch) when on the stop. If one timer is capable of 4 stages on time, could the stop and shifter be wired into the box using the same timer so I'm not shifting while on the stop? Is this even possible?
I apologize in advance for my complete lack of knowledge or correct use of terminology.
Jeff
jlundy is offline   Reply With Quote
