Old 10-17-2018, 07:09 AM   #11
nhramnl
Liked 358 Times in 83 Posts
Default Re: dawn in MT slicks
Originally Posted by Eman View Post
I'm a Palmolive man myself. It does work and for the ease and cost of it why not? I just put new Hoosiers on and did it, why not? I don't use screws just wipe the rim and bead with acetone before filling and if you want you can spray the bead with hair spray, it help prevent them slipping on the rim. I've never filled the holes but use a scotchbrite on a die grinder to remove any burrs. I've used wheels with holes and never filled them and run tubeless with no problem.
For what it's worth, this is what a lot of guys are doing today, with the exception of the dish detergent. That practice started many years ago, almost exclusively with Firestone/Firehawk/Phoenix bias ply slicks. The rubber that made up the sidewalls was so thin that you could wet a mounted tire with soapy water and watch all of the little bubbles form on the surface. They would often go flat in a couple of days. I could certainly be wrong, but I don't know of another tire (especially any radial) that exhibited that behavior.
Old 10-17-2018, 07:31 PM   #12
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Hoosier = no soap and no leaks!
Further, it's the year 2018, who runs rim screws?
I go 1 teens in my door car and 1.0 in my dragster in 60 foot without rim screws!
