Old 12-18-2016, 11:07 AM   #11
Todd Gross
Liked 54 Times in 24 Posts
Default Re: Chrysler Solid Roller Lifter Question
Originally Posted by ss3011 View Post
Most of the Chrysler lifters have no band , and no holes drilled for any flow to the pushrod seat . Jesel makes a keyway lifter, that will oil through the pushrods, to work in a Hemi , but with the bushings, and all the machine work , it gets real pricey . If someone made a lifter that was similar to the way a Chevy lifter works, but for a Hemi , then that would solve the problem . Then a guy could buy hollow style pushrods , and oil the rocker balls directly through the pushrods. That is what I am looking for.
Your right. The Chrysler lifters have no oil band because BB Mopar blocks are not gun drilled through the lifter bores for oiling ( unless aftermarket or specialty machine operation).
I had several B1/TS engines that I outfitted with spray bar oiling in the valve covers. Still had intake galling issues. My resolution ended up providing room for larger diameter, heavier walled push rods to combat flexing ( pole-vaulting ) push rod that caused impact galling.
Todd Gross
3323 FS/E,F
Todd Gross is offline   Reply With Quote
Old 12-18-2016, 12:51 PM   #12
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
I have to push back on your statement . All the factory blocks are drilled to oil the lifters , they were available with hydraulic lifters , so they needed this oil gallery .
Old 12-18-2016, 12:58 PM   #13
Todd Gross
You are correct. I really have to learn not to post things before I have coffee.
The blocks I was using and thinking of were Indy and KB. They did not come with lifter oiling...duh!
Todd Gross
3323 FS/E,F
Old 12-19-2016, 11:49 PM   #14
Jeff Teuton
Liked 325 Times in 50 Posts
How about Comp Cams. We used their stuff for years in the Hemi motors before they went around the world nuts.
Jeff Teuton 4022 STK
Old 12-20-2016, 12:30 AM   #15
Allen Sherman
Banned
Liked 5 Times in 3 Posts
Same as Jeff said, comp cams makes a pushrod oiling lifter. I've used them successfully. Also look at your pushrod tip material, trend makes some material that won't gall, a little pricey though...just some FYI
Allen Sherman is offline   Reply With Quote
Old 12-20-2016, 02:02 AM   #16
ss3011
ss3011's Avatar
I have been using Comp stuff , but did not know they had a lifter that oiled up through the pushrod . I will check with them also .
Old 12-20-2016, 08:02 PM   #17
monte442
Liked 3 Times in 1 Post
Crower and Morel also offer it.
monte442 is offline   Reply With Quote
