Old 09-22-2016, 01:12 PM   #11
340Cuda
Liked 805 Times in 341 Posts
Default Re: "Second Best" 15" Trailer Tires
Clark,
Four years is probably a good rule of thumb. My new E rated tires can go to 80 pounds but the wheels are not rated that high, I am running 70 as before.
Bill
Old 09-22-2016, 01:54 PM   #12
voltdr
Liked 100 Times in 51 Posts
I don't care which tire brand or size you run, but get a TPMS system. I have been using one from EEZTIRE for more than 2 years now. The peace of mind it gives me will traveling from Texas to Las Vegas to Indy is immeasurable. Easily installed and it can handle up to 22 tires. It will monitor each tire and let you know if you are having a problem and pinpoint it to the specific tire. You can set low/high pressure warnings and high temp warnings as well. It easily changes for use without the trailer attached.
It's really nice to turn it on while loading up and it will tell you the pressures of all the tires so you don't have to go and check each tire separately.
Dan Foley
SC4698
http://www.ebay.com/itm/TIRE-PRESSUR...1R14ds&vxp=mtr
voltdr is offline   Reply With Quote
Old 10-25-2016, 12:30 PM   #13
The Hitman
The Hitman's Avatar
I have an overloaded 24' trailer and I run Trailer King ST Radial Trailer Tire 10 ply load E,
Great tire, I got tired of carrying multiple tires, so I decided I would try them all, at one time I had 4 different brands on my trailer, The Trailer King's held up the best..
The key is DO NOT OVER INFLATE!
SFV Motorsports
IHRA MX36
Dan "The Hitman"
The Hitman is offline   Reply With Quote
