#11 |
Liked 1,439 Times in 301 Posts
We have been using the trend limited travel tool steel lifters that we get from Alan Roerich. We then send them to dynacron to get treated. We run 200 seat and over 400 open on nitrided cast cams with hundreds of runs. No issues.
James Schaechter 3163 STK |
#12 |
Liked 68 Times in 31 Posts
Cast nitrided with Dynacron coating on cam and
Lifters works awesome, ran 2 yrs and cam looks Perfect.
Ron Mattson 5015 STK |
#13 |
Liked 799 Times in 236 Posts
James and Ron, a couple of questions:
- Are you having the cast cams nitrided and then Dynacron coated? - Is a non-Dynacroned, nitrided cam is okay? - If you're going to Dynacron the cam, do you get a non-nitrided cam to start with? - What are you doing for break in? Feel free to PM me if you wish. Thanks in advance for the advice! ![]()
"That'll never work....." |
#14 |
Liked 11 Times in 5 Posts
Gday,
Very interested in the reply to the above question if you dont mind sharing, also any issue's with different oils or additives affecting the coatings? Cheers Paul |
#15 |
I have been nitriding the cam and having it
And the lifters both Dynacron coated. Have Used all types of oil with no issues. I have been Breaking in with soft springs also!
Ron Mattson 5015 STK Last edited by ron mattson; 05-21-2016 at 10:05 PM. Reason: Added info |
#16 |
Gday Ron,
Thanks for the response! Cheers Paul |
#17 | |
Liked 1,879 Times in 422 Posts
I thought I got you guys a set or two of solids as well. Not sure if that is correct, or where they went, maybe in the 396 in the Corvette. By the way, if anyone is concerned about oil flow to the top being too much, they have a pushrod cup with a 0.014" orifice. They can probably be added when ordering at a low or no cost upgrade. Several DLC coating applicators say they do not like the Driven oil, and will not offer support to those using it. I do not know the story behind that, other than a few years ago, there were some lifters that the coating came off of in NASCAR engines. The Cup guys use less spring pressure than most Stock Eliminator guys use. No DLC coating applicator I know of will suggest or support their coating applied to a lifter being run on a cast iron cam core. I have had some tell me to coat the cast iron cam and the lifter, but I have not tried it, nor do I intend to.
Alan Roehrich 212A G/S |
#18 |
Yes we had solids for the 396 as well.
#19 |
Liked 308 Times in 103 Posts
Robert,
I haven't used any coatings,use the P-55 cores,non- nitrided,PPPC lifters uncoated. Use lucas break in oil and race oil. Have switched them and broke them in to another cam,check the crown on the bottom of lifter if has .0012'' or more and smooth use again. Mike Taylor 3601 |
#20 |
Dynacron is not a dlc it is a tungsten disulfide
Lubricant coating and has a natural affinity or Attraction to any oil, kinda has a property to keep Oil on the surface making it a double benefit.
