Old 02-13-2016, 06:26 PM   #1
Tim Bartlett
Default onan help
Need help on onan 7500 diesel generator it is a 1996 model in a freightliner chassis motor home. The unit cranks fine but after it runs 2/3 seconds it appears the starter trys to engage again. Have replaced the starter, solenoid, both rocker switches and relay. Any help is appreciated
Tim Bartlett is offline   Reply With Quote
Old 02-16-2016, 09:16 PM   #2
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
Default Re: onan help
I have not run across one that ever did that.
I will look into it for you tomorrow.
I am an Onan repair tech and have worked on many of those....
A 7500 diesel should be a variable speed inverter/generator......Yes?
Unfortunately the inverter section is a sealed unit and the control is part of that inverter section....NOT serviceable....
I will look at a machine's electrical print and trace out the starter circuitry but it is not a good scenario since you have changed most components already.....
If you can give me the Model Info off the I.D. label it would help.....
Looking in the Service Manual for a typical Cummins-Onan 7500 diesel inverter-generator this morning did not show me anything that is likely to be a simple fix for this machine.
The starter is controlled directly by the Controller PC board located inside the Inverter section and as I said not serviceable...
The starter should be de-energized when the engine reaches 800 rpm and the controller is always monitoring engine speed from output of the generator end......
Unless a wire is damaged, shorted, or possibly output is incorrect.......your Inverter-Controller is likely bad.
Not an uncommon issue on those units and since it is 20 years old.....anything is possible......
I would start the unit with the covers removed and pull the starter solenoid B+ wire off the starter and put a voltmeter on it to see if it is actually re-energizing after the unit is running.
I would also monitor output power and see if there is anything changing there at the same time.
The Inverter-generators can do some very difficult to diagnose things...
I had one that would "full field" the power end during cranking. The starter could barely turn the engine over due to the high field strength.....You think the starter or battery/cables are bad but it was the Inverter-control unit....
Rich Biebel
S/C 1479
Stock 147R
Old 02-17-2016, 10:51 PM   #3
Tim Bartlett
Rich the model number is 7.5 dkdfj and the serial number is L953459253. If I start the unit and pull the b+ wire off should the unit continue to run? It appears the same wire goes to the fuel pump also. You can crank the unit and when the starter trys to reengage if you pull the b+ wire off the noise goes away but the unit stops running. Where is the inverter/controller located. Thanks for your help
Old 02-18-2016, 08:14 AM   #4
Rich Biebel
Ok Tim, ignore everything I previously posted......
A DKD is a completely different generator from what I was thinking you were talking about.
You have an industrial type open unit. I rarely see them anymore....
I cannot find anything in the service manual or operators manual that clearly says what is used for crank disconnect as it is called.
Something inputs to the control board mounted in the square switch box area to signal the engine is running.
If I was working on it and had a visual on it I could better tell you what it has or doesn't have.
Some Onan's used a simple switch that worked off the governor.....as speed came up the switch opened....I don't think it has one but would have to look for it.....Speed is fixed on those machines and does not have a governor.....Uses injection pump stop to set speed. It might still have that switch and it might be under the rear cover area.....generator end...
Might use AC output.....Might use alternator output....possibly oil pressure......
I have not worked on one of those in years......
Rich Biebel
S/C 1479
Stock 147R
Old 02-18-2016, 09:44 PM   #5
Tim Bartlett
Rich thanks again for the help. I have the original installation manual which includes a wiring schematic. I am far from an expert when it comes to reading the schematic but there is a item in the diagram labeled relay starter protection, do you think something wrong there could be the problem. That item has two circles labeled AC attached to it.
Old 02-19-2016, 08:43 AM   #6
Rich Biebel
Tim it is possible that the output from the alternator is used as a signal to the controls to indicate the engine is running. That is used on a lot of old generators. I doubt it though as most machines that used that had an alternator with what was called a Tach output terminal.....
A battery charging alternator produces ac and is rectified and regulated to charge the battery. As I recall those DKD's used a small alternator just like the one sold as a Shogun for racecars....Had a separate rectifier/regulator.
You should be able to run the unit and pull the starter solenoid wire off the solenoid without it shutting off in my mind. Starter solenoid just gets 12volts + to crank and de-energizes once it runs. If you can run it without the starter kicking back in you can test for proper battery charging output.....
I can look at circuit diagrams when I have a chance and if I see something that helps I'll get back to you...
The info shown online for those machines is old.....and covers a lot of different models......
Rich Biebel
S/C 1479
Stock 147R
