Old 12-02-2014, 04:31 PM   #11
buzzinhalfdozen
Liked 11 Times in 8 Posts
Default Re: Watch TV in a motorhome
Bobby, Racing Ricki is correct your antenna is most likely not the issue (unless possibly the booster is not being powered) older TV's cannot process the digital signal without the converter. In my opinion your best bet is to replace that TV with a flat screen, you can buy a no name for less than 200 dollars, great picture and you're losing 20 pounds from your motor home. I did however change out the antenna head on my goose neck for a "bat wing" style and got twice the number of channels.
Joe Buchanan SS/BX 3117
