Old 08-08-2013, 08:58 PM   #11
james schaechter
Liked 1,434 Times in 299 Posts
Default Re: 1990 Corvette Stick Stocker
Cool build! Thanks for sharing!
James Schaechter 3163 STK
Old 08-09-2013, 10:22 PM   #12
Glenn Hayes
Glenn Hayes's Avatar
Liked 18 Times in 12 Posts
Your off to a great start! Thanks for sharing your adventure with us!
Old 08-10-2013, 02:58 PM   #13
SS 230
Will the '90 dash bolt up with the same brackets and fastners as the '84(direct replacement)?
SS 230 is offline   Reply With Quote
Old 08-10-2013, 08:09 PM   #14
Greg Hill
Liked 279 Times in 68 Posts
I'm not a tech guy but if I were you I would find one and ask about the master cylinders and aftermarket pedals. I've never seen that in a stocker.
Greg Hill 4171 STK
Old 08-10-2013, 09:11 PM   #15
Chad Rhodes
I was thinking the same thing
Chad Rhodes 2113 I/SA
Old 08-15-2013, 08:00 AM   #16
Pierce Jones
Liked 15 Times in 9 Posts
Greg and Chad - Thanks for the heads up. I've kept the original brake pedal and master cylinder assembly. I could re-install it along with a stock clutch pedal if required.
SS 230 - Great question...... I'm not sure. If the car comes out of the gates as an 87, 88 or 89 it wouldn't be the end of the world.
Pierce Jones is offline   Reply With Quote
Old 08-15-2013, 10:30 AM   #17
countrypuppy4865
countrypuppy4865's Avatar
Liked 228 Times in 70 Posts
84-96 is considered a C4. I am not 100% certain, but I think the main body structure is the same. So, I would think the 90 model dash would bolt up.
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
Old 08-15-2013, 09:11 PM   #18
Chad Rhodes
It's all interchangeable, I've had several of those cars.
Old 08-19-2013, 09:50 PM   #19
Pierce Jones
For those unfamiliar with the Corvette IRS, here’s a side shot. The entire rear end assembly bolts into the car. The composite spring attaches to the outer knuckle. 2 control arms per side bolt to the chassis with an aluminum bracket. What’s not shown here is the aluminum torque arm that supports the transmission tail housing.
Uploaded with ImageShack.us
As mentioned early I will be installing a 12 bolt because it was free (thanks dad) and familiarity. I started with a stock 12 bolt. After chopping the brackets and carefully measuring I chopped the ends off in a chop saw. Since the suspension needs to be of stock type I decided to run a torque arm set-up similar to the F-Bodies. I bolted and tack welded the tubes to the housing.
The lower control arm mounts were made of 2” square and bolted in the stock location as the IRS arms.
I was able to design a mount that would attach the spring, sway bar, shock, lower control arm and panhard bar. Thanks to BDM Millwright who CNC plasma cut the mounts for me. The material is ¼” mild steel. The axle ends are the large bearing Moser units. Through-out the process I simply relied on my trusty Mastercraft electronic level.
I decided to run the torque arm up the passenger side of the car. This will hopefully give more room around the shifter when pulling the tranny out. The torque arm mount is made out of 1/8” steel and will be bolted and welded to the rear end housing.
I fabricated a 2” square mount for the composite spring, which mounts to the IRS mounting tabs. The spring had to be shifted rear to accommodate an extra thick rear cover.
