Old 01-28-2013, 06:54 AM   #11
jmcarter
jmcarter's Avatar
Liked 3,202 Times in 977 Posts
Default Re: Need help with rules
Jon, good call; you can use a swing out bar if that helps...
Jim, bolted in is permissible; this is copied straight from the rulebook general reg section so of course the wheel tub comment doesn't apply to a Stocker:
"All vehicles with OEM frame must have roll bar welded or bolted to frame; installation of frame connectors on unibody cars does not constitute a frame; therefore it is not necessary to have the roll bar attached to the frame. Unibody cars with stock floor and firewall (wheeltubs permitted) may attach roll bar with 6-inch x 6-inch x .125-inch steel plates on top and bottom of floor bolted together with at least four 3/8-inch bolts and nuts, or weld main hoop to rocker sill area with .125-inch reinforcing plates, with plates welded completely"
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 01-28-2013, 07:43 PM   #12
rcjonny
Yes you can have it bolted in it is in the nhar rulebook is was looking into it myself
rcjonny is offline   Reply With Quote
