Old 07-19-2010, 04:28 PM   #11
Steve Williams
Default Re: crash......
Originally Posted by koch3031 View Post
on the comp forum the driver said the accelerator stuck thats what caused the crash
A friend of his said that. Another person that claims to have loaded up the wrecked car said that the driver told him that he got on the brakes too hard and that the throttle was stuck after the he got off the brakes. Either way, his racecar is wadded up.
Steve Williams is offline   Reply With Quote
Old 07-19-2010, 06:30 PM   #12
CycloneFE
CycloneFE's Avatar
Liked 2 Times in 2 Posts
http://www.insidecompracing.com/showthread.php?t=5151
Old 07-20-2010, 11:15 AM   #13
sprnova
sprnova's Avatar
Originally Posted by herbjr View Post
First off you know these comp guys push the clutch in or neutral the cars at the stripe, then get the chutes out. There is no way the throttle stuck or the car would have kept going straight and the shutoff would have killed the motor. He hit the brakes to avoid a CIC and the back end got loose. He couldnt scale after the wreck as the car lost parts so he should be out. WHen the car got up it looked like it was going to roll I dont know how it didnt.
Mr Herb I dont know who you are or if you were even their, but your simple mind seems to have it all wrong. He wasnt trying to SAVE INDEX it was after the finish line. And yes the gas pedel was stuck. Brandon did a good job considering what all he was going through in such a short time. Thank God he is ok and the car can be fixed. The car is really not as bad as the wrecked looked.
Josh Edwards 752A
SS/GM, SS/BX, I/SMA
sprnova is offline   Reply With Quote
Old 07-20-2010, 12:01 PM   #14
larry dowty
Liked 11 Times in 4 Posts
josh i wasnt there, but i was told from people at the finish line that it took a nose dive before the finish line, he wondered if that finsh line strip started the right tire to lock up when he went across it ?
larry dowty 6388 SS
larry dowty is offline   Reply With Quote
Old 07-20-2010, 12:28 PM   #15
sprnova
sprnova's Avatar
None of the skid marks I saw when driving up to the car started at or before the finish line, they were a little passed. From what he said the peddle stuck and he was shutting everything down pulling chutes pushing in clutch and pressing the break he may have got on them a little harder than normal (thus causing the caliper to break ?) It just came around on me. Bad deal to a great person.
Josh Edwards 752A
SS/GM, SS/BX, I/SMA
Old 07-20-2010, 07:02 PM   #16
larry dowty
I am just glad he is ok he is a great guy that survied what could have been a real bad crash
larry dowty 6388 SS
