View Poll Results: .031" Dykes or .043" Rings ?
.031" Dykes 41 33.88%
.043" .155" radial moly ring with lateral gas ports 39 32.23%
.043" .134" radial moly ring with lateral gas ports 31 25.62%
Other, Make suggestion 10 8.26%
Voters: 121. You may not vote on this poll
Old 04-26-2009, 05:19 PM   #11
Bub Whitaker
Default Re: .031" Dykes or .043" Rings ?
[QUOTE=RPinoski1;117276].043 With no lateral gas ports. Lateral ports create a vacuum leak on the intake stroke so now not the way to go anymore.
Napier second ring with twice the end gap as the top ring. Eliminates top ring flutter.
Remember: This type of ring as with all secong rings is for oil control only hence the larger end gap.
-------------------------------------Quote
Vacuum leak on the intake stroke, not so... look at the top ring after run and you will see wear mark on the bottom inside whare it seals on the intake stroke... also second ring, especially napier not only controls oil but its reverse taper face aids the intake charge...
Bub Whitaker
Bub Whitaker is offline   Reply With Quote
Old 04-26-2009, 06:15 PM   #12
Greg Barsamian
Liked 427 Times in 97 Posts
Talking Re: .031" Dykes or .043" Rings ?
quote from Robert Pare's music book,
"Iisten to that Whitaker guy, he's built a couple of motors"
Old 04-26-2009, 09:15 PM   #13
John Duzac
John Duzac's Avatar
Liked 83 Times in 20 Posts
Smile Re: .031" Dykes or .043" Rings ?
Bub Whitaker: You have a private message.
John Duzac D/S 4448 STK
John Duzac is offline   Reply With Quote
Old 04-28-2009, 02:31 PM   #14
PATTERSON
.043 pro series .155 rings with vertical gas ports would be far better than the dykes and proper ring clearance would be a key factor also. There are also diamond finished rings which would be a great option. There are some other options that are popular on these piston I can explain to you if you want to call me. take care 316-775-7771
PATTERSON is offline   Reply With Quote
Old 06-11-2009, 06:22 PM   #15
Bub Whitaker
Well Patterson, looks like we are in agreeance as far as .043 with lateral gas ports, regardless of radial wall over Dykes ... you take care also...
Bub Whitaker
Old 06-15-2009, 12:54 PM   #16
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
My LT-1 had 1/16" top ring grooves and I used std. top rings with cutback seconds and very low tension oils......I have used the .031" dykes with spacers in a 5/64" groove if I remember right in my 350/255 back in the '90's......Do the .043" rings go in a 1/16" groove with spacers.....and the rings are where the gas port grooves are cut ? .......the spacer would be pretty thin and I have no experience or knowledge of the gas ported ring setup. Just curious about this and I might need the knowledge for a future Stocker engine project for someone else........
Rich Biebel
S/C 1479
Stock 147R
Old 06-15-2009, 01:19 PM   #17
Woodro Josey
Liked 3 Times in 1 Post
Well Patterson and Bub, i too agree with you guys,,,,Total Seal now can supply you with Gas Ported spacers to go with the .043 Top Ring. I haven't seen this metioned but, it is illegal to machine Lateral Gas Ports in a Stocker piston,,,sooooooo!!!!!!!!!!!! The .043 Diamond Cut ring or 1/16 or 5/64 Diamond cut is the way to go but, a little pricey!
Woodro Josey 2002 STK
Woodro Josey is offline   Reply With Quote
Old 06-16-2009, 07:47 PM   #18
Ed Wright
Ed Wright's Avatar
I'm suprised at the poll resuslts. Didnt know anybody still used dykes rings.
Ed Wright 4156 SS/JA
Old 06-16-2009, 09:29 PM   #19
larrylomascolo
Liked 66 Times in 29 Posts
I used the .031 dykes ring ordered , tight and lapped all 8 for a s/s motor,worked great ,alot of time and sore fingers ,does anybody still do this today,
Old 06-17-2009, 06:37 AM   #20
Tilley2007
Guest
Posts: n/a
What about the .7 & .8 mm rings & 2 mm oil rings for engines in the 8,000-10,000 rpm range?
