Old 09-23-2009, 07:16 AM   #11
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Default Re: 1150 dominator Questions
I'd try an 850 on that motor. .Not enough compression,or rpm to justify anything larger. .........Probably would work if it was still on nitrous,but way to big without it...........Like Rich said ,It'll probably pick up a bunch of ET with a smaller carb..........Tom
Old 09-23-2009, 02:06 PM   #12
Floyd Staggs
Floyd Staggs's Avatar
Liked 229 Times in 99 Posts
How about on a 10 3/4 to one 540 with .714, .714 cam etc? Is the 1150 to big? That's what I'm using.
4000 lb pickup, pump gas, 10.72 @ 122 best.
Floyd Staggs 787 SST
Old 09-23-2009, 04:25 PM   #13
Tom Goldman
Floyd, I'd bet your short times ,probably up to the 660' would pick up considerably. ......I've seen guys use way to big a carb and have success,but I've also seen many who struggled with the problem Bob is having. .....Bottom line is you have to try different carbs to see which is best for your combo..........A while back,.I tried a 1050 on our S/ST AMC Spirit which has a very healthy 401 in it. 13 TO 1, big roller ,ect .....It picked up about 1 mph ,but lost over 2 tenths in ET! , compared to a good 850 carb. ......Tom
Old 09-23-2009, 04:37 PM   #14
Floyd Staggs
Tom, the price was right on the 1150. A buddy of mine had it and wasn't using it, so there you be. I can borrow a 1050 and try it. Jet it the same 94 sq and see if there is any difference.
Thanks,
Old 09-24-2009, 07:45 AM   #15
Floyd Staggs
Tom, OT, I just got one of them F.A.S.T. air fuel ratio recorders, their instructions leave a little to be desired. Do you know how to adjust the carburetor to get the desired numbers? What are the desired numbers?
Old 09-24-2009, 04:09 PM   #16
Tom Goldman
A/f meters are great at showing you where the ratio is in relation to the car on the track. ....BUT correcting the fuel curve can be tricky. ...Most of the real experts I've talked to recommend 12.2 to 1 as a safe a/fr to shoot for ,but the car may want to lean out more as you progress down the track,and some cars work better with a much richer ratio at the starting line...........Jetting ,air bleeds and ignition timing all come into play. ...That why its best to establish a base line on the dyno before tuning on the track. .......If the a/fr is in a safe area, I'd start by moving the ign timing to see if it is covering any jetting deficencies...........Tom
Old 09-24-2009, 05:02 PM   #17
Floyd Staggs
Thanks, Tom,
I'm just looking to keep it consistent and try to keep up with the changes in the weather.
Old 09-26-2009, 10:23 AM   #18
Bob Alberty Jr.
Ok here is the latest.
Tom the air bleeds have been messed with at some point in this carbs life. I only brought a small selection of guage pins home, the largest being a .030, and it will fall in and wiggle, I have a few 1050's to choose from,thank goodness for friends, so we will try it next friday night with less carb. Any particular list number I should look for?
I went ahead for the sake of nothing better to do, and added 7.5 power valves, and pulled the jets back to 95's, and it idles continuouse By that I mean the rythem prior to today would change as it idled, meaning {roll your "R"s} rowd rowd rowd rowd rowd then it would change tone for a few seconds and eventualy go back, now it just sits there with the rowd rowd sound never fluctuating, it ran for 15 minutes just now.And didnt build heat over 175.
I will get the 1050's on it and see what it changes. Thanks for all your help.
Bob Alberty Jr. is offline   Reply With Quote
Old 09-26-2009, 03:20 PM   #19
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
A 9375 is a good 1050 to look for and try.....They run well and jetting should be 92's as a baseline. Anywhere from 88 to 94 is a normal jetting range on those. Holley's generally do the Holley "gurggle" and it is pretty normal.....If it holds a steady rpm without sinking it is ok....If it loses rpm after it runs a while and goes back up after you rev it a few times...it's too rich...fixing that is not always just a matter of an adjustment.......Too big a carb or cam or both often slows a car down......
Rich Biebel
S/C 1479
Stock 147R
Old 09-26-2009, 04:21 PM   #20
Floyd Staggs
Got my meter put on this morning, it is way fat, 9.8 idle. Gonna drop back to 92's and then wait to make a pass at Phoenix next Thursday and go from there.
