Old 06-09-2024, 10:54 AM   #151
Stewart Way
Liked 70 Times in 22 Posts
Default Re: New website: "What class does this run?"
Dwight
Looking at the 1968 Chrysler 426 Race Hemi specsI see the compression number is a negative likely because the piston is listed as a dish rather than dome. No big deal , just thought you might want to change it.
Thanks for the great site. Can't image the time and effort that went into this.
Stewart Way 2424 SS
Old 08-04-2024, 10:48 PM   #152
Justin McIntosh
Justin McIntosh's Avatar
How do you figure GT classes on classracerinfo? I?m curious what class a 66 Chevy II sedan/post would fit in with a 305hp rated 346 LS1. Thanks!
The automatic transmission is the reason for the wussification of America
Justin McIntosh is offline   Reply With Quote
Old 11-07-2024, 01:48 PM   #153
Chuck Weissberg
Liked 49 Times in 26 Posts
I believe there may be a mistake under the 2005 Pontiac 364 engine. They have it noted as "number of cylinders 6 , while I believe it should be noted as 8
Announcing a new website that will make answering those questions a lot easier.
Did you ever wish that all the technical information was available in one place and as easy a clicking your mouse? Your wishes have come true here
http://www.classracerinfo.com
Enjoy!
Dwight Southerland
Chuck Weissberg is offline   Reply With Quote
Old 12-17-2024, 11:31 AM   #154
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
I will be working on the end of year changes posted by NHRA in the next few days, Also, there are several additions in the accepted products lists that will be added. I will post when they are all done.
Old 02-09-2025, 06:28 PM   #155
Wrenchead
It appears the 2002 Z06 is absent from the classifications.
The base Corvette @ 345 is listed but the 405hp Z06 is not.
Is there a reason for this?
Wrenchead is offline   Reply With Quote
Old 02-11-2025, 11:46 AM   #156
Dwight Southerland
The Z06 option is not listed in NHRA's Tech Bulletins or Class Guide for 2002. Only combinations recognized by NHRA are included.
See these:
NHRA Class Guide Sheet Chevrolet 2002
NHRA Tech Bulletin Chevrolet 2002
Old 03-30-2025, 02:08 PM   #157
Rag71
Liked 9 Times in 5 Posts
Don't see any factor #'s for 1971 Hemi Cuda in SS wanted to see what they run today used to always be in SS/D &DA TY
Rag71 is offline   Reply With Quote
Old 04-08-2025, 11:27 AM   #158
Dwight Southerland
Thank you for pointing that out. As I investigated the issue, I found that it was caused by erroneous data in the database. I has been corrected now.
Old 04-09-2025, 09:12 AM   #159
Tim H
Tim H's Avatar
Liked 484 Times in 160 Posts
So when can I expect to see your '71 Hemi Cuda in SS ?
