Old 10-16-2021, 09:09 AM   #1
Todd Geisler
Liked 345 Times in 149 Posts
Default 8.50 index build
Hello all, long time member, just never had a class car.
One year ago I had a bad top end wreck with my 8.50 index Malibu that I built, owned and raced for 27+ years. Car made a hard left past the finish line, put me into the wall which then caused the car to barrel roll as many as 7 times I'm told. I don't remember any of the accident, so no apparent cause was found.
A couple weeks after the crash I was able to source a body to begin building again. My dream car was gone so the new car would simply be a purpose built race car, chosen for ease of parts availability, low purchase cost and light weight.
I have many, many pics of the build in detail, not sure how much interest there would be to see this project.
Todd Geisler is offline   Reply With Quote
Old 10-16-2021, 09:40 AM   #2
Keith 944
Keith 944's Avatar
Liked 1,877 Times in 577 Posts
Default Re: 8.50 index build
The first car looked very nice, i'm sure this one will be too. I am always interested in any build!
Keep up the good work and keep posting please!
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 10-16-2021, 11:22 AM   #3
Todd Geisler
Will do, gonna be alot of pictures to post. lol
Old 10-16-2021, 11:30 AM   #4
Todd Geisler
Found alot more rust than I was hoping for. One area I really didn't want to get into was the front frame rails which have a reputation for rusting out under the master cylinder and combination valve.
I tried ordering a replacement frame rail kit but didn't like how it was going to install, plus I found an issue with the factory placement of the passenger rail, so I decided to make my own. Drew them up on CAD at work and cut them out on the cnc plasma.
Old 10-16-2021, 11:37 AM   #5
Todd Geisler
So many holes to weld up in the shock towers...
Body back from media blasting...
In the mean time parts were ordered and slowly starting to come in.
Old 10-16-2021, 12:01 PM   #6
Todd Geisler
At this point the front end was rebuilt as far as I could go for the time being. I was ready to start the tube work but was waiting for a bay to open up at work to get started.
So in the mean time I worked on building the rear housing. First was a mockup and measurements of the rear wheel/tire combination.
Then the rear could begin with welding on the 4 link doubler plates.
Housing and 4 link brackets being fixtured up.
Once all the welding was done the housing ends could be fit which is a very time consuming/tedious process to get them perfectly square to the axle centerline.
A fixture was then made to hold the housing to the chassis table.
About the time I was completing the work on the rear, a bay opened up at work so I transferred the car to its new home.
...and now tube work could begin.
Old 04-13-2022, 02:07 PM   #7
Todd Geisler
Small update on the most recent progress. First off was to prepare to bond the roof supports to the cage. This required stripping the powder coat off to bare metal, yet not damage the powder coat outside of the bond area. Alot harder than it should have been because like a dummy I put the tubs in the car and my access to reach the area was gone now. Had to reach from outside the car making it quite challenging.
Old 04-13-2022, 02:16 PM   #8
Todd Geisler
Next up was to finish up the parachute. The old chute bag was badly sun faded so I got a new replacement. The aluminum spring can was pretty beat up from the crash so I straightened it as best as I could then had it powder coated in an effort to save it. Lastly, a new chute cable installed.
The last few things were to install new door lock cylinders then sandblasting the trunk latch & hardware then installing as well as the trunk lock cylinder.
Old 04-13-2022, 02:29 PM   #9
jims5600
Liked 21 Times in 9 Posts
Todd I love following this build. Your craftsman ship is awesome!
I had a roadster and three dragsters. There primitive compared to
what your doing to that chassis. I never knew there was that much
involved with a fast door car chassis.
Keep up the great work and best of luck.
Jimmy
jims5600 is offline   Reply With Quote
Old 04-13-2022, 02:42 PM   #10
Todd Geisler
Jimmy
Thanks Jimmy for the kind words. I was sharing the build as often times people don’t realize how much work is entailed in a full build start to finish.
