#1301 |
Liked 544 Times in 213 Posts
Cutting grooves in the lifter bores can’t be undone.
Using the EDM hole lifters is an option and can be changed. Some Stocker racers use Schubecks or Trend lifters and run tons of spring pressure. The engine I built was low buck and the lifters were cheap. It had good oil pressure and never hurt the bottom end You could have used the edm lifters with no grooves and if that worked you were good. If it didn’t you could step up to better lifters. No grooves to complicate the build.
#1302 | |
Todd Greene |
#1303 |
Grooves are .006, no edm holes in the lifter. This engine ran fine for years with grooved lifter bores (as have others), current oiling issues are not related to this.
Todd Greene |
#1304 |
Liked 10,781 Times in 2,241 Posts
The groves look wider than the thickness of two hairs.
#1305 | |
Liked 373 Times in 129 Posts
(just ask Dissident) carry on.......just be sure to show us the results. |
#1306 |
Liked 73 Times in 36 Posts
I fully realize that I have no skin nor treasure in the project that Todd and Autumn have shared.
![]() However, when it comes to some technical items and issues, I think it is necessary to make those issues obvious before one goes down a problematic pathway that may be paved with lots of "he said, they said, everybody knows..." kinds of guidelines. For a SBC (2.45" mains, 2.1" rods) with normal racing clearances, it is worthwhile to note the resultant internal oil leakage sources. These data are as listed from items indicated: Lifters (16) = total diameter of an orifice = 0.2323" Cam brgs (5) = total diameter of an orifice = 0.2369" Rod brgs (8) = total diameter of an orifice = 0.2899" Main brgs (5) = total diameter of an orifice = 0.2476" Will leave it to others to evaluate what those orifices flow in gpm at various pressures. It is quite eye opening! ![]() Anyway you might look at it, that is a lot of leakage when you consider whatever psi one might want to evaluate. A builder is logically charged with the responsibility of how much and how to control the leakage paths. Sorry for the brief hijack of this otherwise very interesting thread. Regards to All, HB2 ![]() Dissident Last edited by Dissident; 06-26-2019 at 02:40 PM. Reason: clean up sloppy writing |
#1307 |
Everyone have a great Independance Day!
Todd Greene |
#1308 |
Many changes happening and lots of work happening.
Todd Greene |
#1309 |
Liked 251 Times in 125 Posts
Tie that hair back!
She may not be running the machine; it's just a great habit to be in. Last edited by Dave Gantz; 07-13-2019 at 09:31 PM. |
#1310 |
She doesn't have safety glasses on either. She also rode in the back of a pick-up last week. Can't tell these crazy kids anything these days!
Todd Greene |
