Old 05-04-2016, 05:43 PM   #121
Default Re: '66 Malibu N/SA
David, You've got a lot more weight to add, judging by picture.
Don't do anything until the car is in running condition. Then bounce it up and down with no shocks and bushings loose. See what you've got then..Report!
Lone Pine, Ca.
Old 05-04-2016, 09:38 PM   #122
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
If he removes the power brake booster and cast iron master cylinder he will have to reset the ride height....
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 05-05-2016, 01:23 AM   #123
Dave Muller
Dave Muller's Avatar
Liked 223 Times in 73 Posts
Lone Pine, Ca.
I don't really plan on changing or cutting springs until after I make a couple of check out passes. Or at the very least get it all together. Just speculating...
Dave Muller is offline   Reply With Quote
Old 05-08-2016, 06:03 PM   #124
Dave Muller
Yesterday I spent a lot of time adjusting the fenders. Got the right side pretty good. Left side is not as good, but it's better than it was, and both doors open without scraping the fender. I think it'll do. Then I went through tightening all the fender bolts and adding the lower front braces.
Next I got into installing the fuel regulator. I never liked removing and replacing the mounting screws underneath if/when I need to remove it in the future, so I worked out a system on my Camaro that I duplicated here. I built a plate as an intermediate bracket. The regulator screws to that, and that in turn screws to the bracket from the top where it's easy to access.
This also mounts the regulator with all four screws instead of just two as with the supplied bracket. Then I worked out the shape of the bracket with a cardboard template and then cut it out from an aluminum sheet.
Here's the bracket installed and the fuel line trimmed.
Then I installed the regulator and a vertical brace to stiffen the assembly. Now it's just a matter of removing three screws from the top to remove the regulator.
Finally I added the sending unit for the pressure gauge and the fuel sample valve. I just need a little section of rubber hose to connect up the sample line. And I also added the starter solenoid as well.
Old 05-09-2016, 08:22 PM   #125
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
Originally Posted by Dave Muller View Post
Sorry it took so long to get around to this.
They are from Proforged Chassis Parts.
I have the pro forged uppers in my 1970 Chevelle
They appear to give more positive camber in my car fooling it thinking it has tall spindles. That is what it looks like to me. Car will be fully on ground this week front and back. I got urethane upper control arm stoppers to put in frame under upper arms as I have cut in half ones in car now. Car also had da thug springs so I look forward to see how it sits too. I think the tall upper ball joints add substantial front suspension travel so I have to make sure my afco shocks will work. Just a heads up from one Chevelle to another. I really enjoy reading your build thread and passing on what i am seeing. Chris
chris ok is offline   Reply With Quote
Old 05-16-2016, 11:25 AM   #126
Dave Muller
Well, it doesn't look too dramatic, but I did get a fairly full weekend of garage time. Mostly doing wiring and plumbing around the engine bay. This included about half of the under-hood wiring, the thermostat, part of the throttle linkage (I'm just waiting on bushings) and I fabricated a bracket to anchor the return springs. I also got all of the gauges set up except for the electrical connections for lighting, plus power for the electric gauges.
I also installed the headlights, which I was a little concerned about. As indicated by the first picture in the thread, none of those parts were installed when I got the car; they were in a cardboard box in the trunk. So I had never seen how it all goes together, but fortunately it was straight-forward enough that even I could figure it out.
Old 05-23-2016, 08:42 PM   #127
Dave Muller
I got a little bit done this weekend. I had to extend the fan shroud that came with the radiator to get it to work. Did that, mounted the fans and wired them.
Then I put the fan/shroud assembly into the car. The radiator overflow is also in at this point, it's the universal one from NAPA.
Then I mounted the relay and fuse and wired them up. The only thing left to do is to extend the white wire into the interior to go to the fan switch.
Today and tomorrow I'm cleaning up and installing the grill. Maybe this weekend the bumper and hood will go on.
Old 05-24-2016, 08:56 PM   #128
Dave Muller
And now the grill is on (sorry, no steaks on it...).
But tell me, how you could not love that face?
Last edited by Dave Muller; 07-08-2017 at 01:09 PM. Reason: Fingers worked faster than the brain
Old 05-24-2016, 11:10 PM   #129
S/ST J718
Dave been watching your build since the being and I have to say I can't wait for it on the track at Wild Horse... plus running the divisional NHRA stuff will open a bunch more racing for you... Keep up the garage time...
Old Nick in Tucson! Hahaha
S/ST J718 is offline   Reply With Quote
Old 05-25-2016, 08:04 AM   #130
RobbieRacer
RobbieRacer's Avatar
Liked 118 Times in 41 Posts
The Car is really looking good Dave. Nice work!!!
U/SA
79 Mustang
