Old 06-19-2019, 07:23 AM   #1281
HP HUNTER
Liked 373 Times in 129 Posts
Default Re: H-I-J '76 Nova re-fit.
Originally Posted by Nmbr1GMfan View Post
Got the crankshaft balancing done today, just need to chamfer the holes we drilled and it's ready.
Your done after you ck the crank for straitness. You might already know this, but its crucial with that balancer that all the bob weights are exactly the same distance away from the radius of the rod throws. I use a drill bit for this.
Old 06-19-2019, 09:22 AM   #1282
Nmbr1GMfan
Originally Posted by Dave Gantz View Post
I remember those "OK Used Cars" signs, too. Funny, today just "OK" wouldn't be good enough, and hey, it's "Pre-owned", The world is nuts, but I'm "OK".
Funny how society re-defines words through time.
Todd Greene
Old 06-19-2019, 10:33 AM   #1283
Nmbr1GMfan
If anyone remembers the Grant quick disconnect saga, I recieved an e-mail from Summit yesterday (1 year to the date of original order) it should ship in 8 weeks.
Todd Greene
Old 06-19-2019, 12:23 PM   #1284
Nmbr1GMfan
HP, I'll make some video for you to see when I check it today.
Todd Greene
Old 06-19-2019, 08:26 PM   #1285
Nmbr1GMfan
Whats the piston to wall clearance going to be?
L2L said .003-.0035, I didn't however mention the block was filled.
Todd Greene
Old 06-19-2019, 09:01 PM   #1286
Nmbr1GMfan
Here are a couple videos I did today of the cranks being checked. I re-setup and checked these again just so everyone could see since it was mentioned. The videos are a little hard to make out but the first video is the old crank with maybe a tick over .001 runout. The second video is the new crank with under .0005
Todd Greene
Old 06-19-2019, 09:09 PM   #1287
Nmbr1GMfan
Lot's more block work to do, started boring today but my time may get a little complicated for a few days, I'll go as much as I can.
Todd Greene
Old 06-20-2019, 07:43 PM   #1288
HP HUNTER
Did you ck the number 4 main, then the seal surface, then finally # 2 then the snout?
Old 06-21-2019, 07:34 AM   #1289
Nmbr1GMfan
No, I only checked the center.
Todd Greene
Old 06-22-2019, 06:55 PM   #1290
Nmbr1GMfan
I finished a bracket for the rear today (not sure if it will work or not), did a little grinding on the collar for the trans. and finished some real "boring" block work. Had so much fun we may do it again tomorrow. Home watching drag racing YIPPEE!
Todd Greene
