Old 03-04-2014, 12:41 PM   #111
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: '67 Camaro E/SA redo
Yep - If we can muster a 5-under car that is consistent I will have reached my goal for this season. I know it will take more $$$ in the motor to run heads up. Plans are to run all the combo races this year at Beech Bend so I can gain some experience at racing the finish line...my weak point.
Rich Taylor
I/SA - 321
Old 03-08-2014, 08:46 PM   #112
HandOverFist
Once again, no good news to report. Arrived at the track this afternoon with high hopes, but I was foiled again. I'm fishing for answers so let me set this up in chronological order.
Half way to the track my partner calls and tells us to make sure we check the transmission fluid level when we arrive. We had none in the truck so stopped at a auto parts store and picked up a quart. My buddy comes out and said they had no Dextron 3, so he bought what was available which was Dextron 6. I thought to myself no big deal.
Unloaded the car and ran it up and down the return road to warm everything up. Shifted fine and I stalled the car a couple of times noting nothing irregular. Pulled up to the trailer where my buddy is waiting to check the trans dipstick level...finds it low and puts about 3/4 of a quart in the transmission. Good to go.
After gearing up I pull the car into the staging lanes prepared to make a pass. My buddy is standing beside the car while I do my normal 1-2 shift burnout then ease forward. When stopped I put it into first gear and ease into the beam...stalled about 2700rpm I bump in and the lights come down. Nailed the throttle and it sounds like it blew the tires off the car...not sure what just happened I shut it down. A track hand looks under the car and says no fluid spilled. I restart and back the car into the oval track for a closer inspection. We talk for a moment and he says the tires never turned at the hit....hmmm. I back the car further into the oval track and try first gear again...it barely wants to pull the car. Second, third and reverse gear seem normal.
I ease the car back to the pits in second gear. Got under the car and check the cable adjustment which is dead on correct. We load the car and come back home still not sure what the problem is. While unloading the truck I grab the nearly empty bottle of transmission fluid and it catches my eye...that quart of fluid is a full synthetic. We use Dextron 3 in this transmission.
Question : Is it possible this was a self inflicted wound? Could a quart of synthetic fluid cause this metric 200 to slip that badly in first and have no apparent effect in the other gears? I'm going to pull the pan in the morning and check for any debris, but I can hear no odd noises coming from the transmission when running. I'm sure Thomas Arnett could say what it is off the top of his head, but it will likely be Monday morning before we talk.
Rich Taylor
I/SA - 321
Old 03-08-2014, 08:52 PM   #113
Glenn Hayes
Glenn Hayes's Avatar
Liked 18 Times in 12 Posts
Rich,
Could be possible internal damage from when the rear end rotated under full throttle?
Glenn
Old 03-08-2014, 09:01 PM   #114
HandOverFist
Originally Posted by Glenn Hayes View Post
Rich,
Glenn
Anything is possible I guess, but when the chunk rotated it pulled the driveshaft out and away from the tailshaft...not jamming it into the tailshaft. Just an oddity maybe after the addition of that fluid? You thinking maybe some odd occilation of the shaft inside the tailhousing from before? It's just strange how it all played out.
Rich Taylor
I/SA - 321
Old 03-08-2014, 09:04 PM   #115
Tim H
Tim H's Avatar
Liked 482 Times in 159 Posts
Definitely not the Dexron VI fluid as it is reverse compatible. It is really a superior fluid to the old standard DEXRON III.
Old 03-08-2014, 09:06 PM   #116
HandOverFist
Sounds like it will be coming out of the car in the morning then.
Rich Taylor
I/SA - 321
Old 03-08-2014, 09:17 PM   #117
Glenn Hayes
It may have taken out the sprag..... possibly...
Old 03-09-2014, 08:11 AM   #118
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
A bad converter would not act like the tires spun....it would act more like you left in second gear...They tend to lose stall speed and get tight and make a car leave very lazy.....
That Dexron VI fluid should not be an issue
When I had a Metric trans I did burnouts starting in 2nd and quickly shifted to 3rd...but that should not really be a cause for a problem.
Sounds like the trans may have lost first gear....or fluid level is low...
Does the ATF fluid look clean and the same color as it was....?
Any slippage in a trans quickly turns the fluid dark and may smell burnt...
Rich Biebel
S/C 1479
Stock 147R
Old 03-09-2014, 12:07 PM   #119
cad
cad's Avatar
Liked 91 Times in 51 Posts
What alternator, crank pulley and bracket are you using?
Thanks
Clark
Originally Posted by HandOverFist View Post
Old 03-09-2014, 05:34 PM   #120
HandOverFist
Pulled it this morning Rich. Fluid looks as new with no burnt smell at all. Pulled the pan and there is a small amount of metal shavings. I'll take it to Arnett in the morning and let him diagnose/repair. Think I will replace the back u-joint while it's out...took a pretty good beating last week. I'm also carrying the convertor with me in case Thomas thinks a flush is in order.
Rich Taylor
I/SA - 321
