Old 05-10-2019, 04:01 PM   #1181
FED 387
Liked 333 Times in 180 Posts
Default Re: H-I-J '76 Nova re-fit.
Front main bearing looks like 1/4-1/3 of the oil hole is covering the corresponding oil hole in the block- any concern??? Fed387
Old 05-10-2019, 06:20 PM   #1182
Nmbr1GMfan
Originally Posted by Tim H View Post
I am a bit alarmed, was hoping to see next pictures of engine installed back in the Nova. Was this a planned tear down to double check everything ?
I'm also alarmed hahaha. Ran for 15 minutes, pulled the pan off and still looked like oiling issues.
Todd Greene
Old 05-10-2019, 06:22 PM   #1183
Nmbr1GMfan
I think the picture makes it look worse than what it is and if that were the only bearing with issues I would be concerned.
Todd Greene
Old 05-10-2019, 06:38 PM   #1184
Question Re: H-I-J '76 Nova re-fit.
Dick, Post # , please. This thing is over 100 pages
Old 05-10-2019, 07:00 PM   #1185
Nmbr1GMfan
Not sure what to think about all this but it's still seems to be an oiling issue. I felt like I had looked at everything, Al Nyhus who has been a great help to me, pushed for me to take a closer look at the plug under the main cap. From the top and also looking from the side above the filter boss I could clearly see the plug was in far, (the bright spot in the picture from the side) blocking maybe 10- 20% of the passage leaving the filter. Is this part of the problem? I don't know, but it could be. Also ya'll do weird stuff with the oil pump I guess, well I don't know if its right wrong or indifferent. It ran with this "doctored" pump so it should be fine but I don't know crap about it, I'm going to take it out and replace it just to try something.
Todd Greene
Old 05-10-2019, 07:00 PM   #1186
FED 387
Mark post 1179 last pic #1 main -fed387
Old 05-10-2019, 07:02 PM   #1187
Nmbr1GMfan
Originally Posted by mark yacavone View Post
dick, post # , please. This thing is over 100 pages
#1179
Todd Greene
Old 05-10-2019, 07:45 PM   #1188
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
The plug is correct under the rear cap. No need to touch it.
The front main bearing was slightly out of position making the hole look misaligned.
Other than that I got nuthin
Rich Biebel
S/C 1479
Stock 147R
Old 05-10-2019, 07:58 PM   #1189
Nmbr1GMfan
Rich, the plug is pressed in far enough to be slightly blocking the main feed oil galley.
Todd Greene
Old 05-10-2019, 09:21 PM   #1190
Originally Posted by Nmbr1GMfan View Post
#1179
Thanks. I missed it the first time.
Not optimal but easiest thing to fix, so far ;-)
