Old 04-09-2019, 06:33 PM   #1131
Nmbr1GMfan
Default Re: H-I-J '76 Nova re-fit.
Originally Posted by Bob Mulry View Post
This looks like a return that just got put back on the shelf without inspecting it....
I am sure that A-Tech would want to know about the problem..
They have always been a good company to work with in the past...
Bob, thats exactly what Atech claimed "it may have been a return". I've just never seen bearings loosely packaged like that before.
Todd Greene
Old 04-09-2019, 06:35 PM   #1132
Nmbr1GMfan
Originally Posted by Wayne Kerr View Post
What was the manufacturing date on the bearings? I agree with Bob, these had to be parts that were returned to A-Tech.
See you at the races,
Wayne Kerr
I'll see if they're still at the shop and check, may have gone back already.
Todd Greene
Old 04-09-2019, 08:03 PM   #1133
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Originally Posted by FireSale View Post
I check it daily. Don't be offended. It's very easy to wind up with Chinese made goods without regards to the name on the box. I think my Eagle crank is machined in America from a blank cast in China or Korea. The new Tacoma Narrows bridge near here is Korean steel. Nothing comparable is available from US manufactures. What a shame
I have King rod bearings and piston rings. Seems to be a US based company. Clevite makes my mains. They are Mahle which is a German company. Very good product.
Good luck getting your mill back up and running.
King bearings made in Israel.
Old 04-10-2019, 06:58 AM   #1134
HP HUNTER
Liked 373 Times in 129 Posts
Simple case of a set Clevite H series bearing out of their original packaging, lets move on to flow numbers and dyno data, and finally track testing data. If you have instant oil to the top of the engine at the hit of pre lubing, thats something you better fix.
Old 04-10-2019, 07:28 AM   #1135
Nmbr1GMfan
Lesson learned.
Todd Greene
Old 04-20-2019, 03:25 PM   #1136
Nmbr1GMfan
Sorry I been neglecting all this but that pesk job has really been getting in the way! Oh look, bearings in proper packaging!
Todd Greene
Old 04-20-2019, 03:31 PM   #1137
Nmbr1GMfan
VP C-12 is the DEVIL! Heads are rusted like crazy, had to pound some of the exhaust valves off the seat, real bad. Little work on the heads today, going to throw everthing in the washer next week.
Todd Greene
Old 04-20-2019, 03:33 PM   #1138
nickh
nickh's Avatar
Liked 659 Times in 197 Posts
Todd I have brand set of standard rod bearings child & Albert's that have been polydyn coated if you want them? They are free to you
Old 04-21-2019, 10:59 AM   #1139
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: H-I-J '76 Nova re-fit.
Every time I shut my cars down for any length of time after using C-12, I fog the motor. That means to fire it up, open the throttle with the engine running and put a couple ounces of Marvel Mystery Oil or even plain old ATF down the carb. When a puff of smoke appears out the headers,shut it off. The oily film prevents rust from appearing on the valve faces and seats and the cylinder walls. C-12 is a very dry fuel and it leaves metal surfaces unprotected from humidity in the atmosphere causing rust. I imagine Florida has more than its share of humidity year round.
Old 04-22-2019, 05:20 AM   #1140
Kenny McCoy
Kenny McCoy's Avatar
Liked 5 Times in 3 Posts
C11 is faster, fog motor with WD-40 after engine cools down use starter button open throttle blades crank it over for about 10 seconds works good in Florida.
Kenny McCoy is offline   Reply With Quote
