Old 07-06-2013, 11:33 AM   #1
impstocker
impstocker's Avatar
Liked 53 Times in 16 Posts
Default 1965 Impala BBC Stocker Update
Since my original Thread got "highjacked" by a lot of non-pertaining bull, here is an update. One of the reasons why i started this thread was 10 years ago when I first built my 68 Impala stocker I was told by a lot of people not to do it because it was a "parts breaker"
I made over 100 passes in that Stick Shift 4095 lb and only broke once, and that was a set of 4:88's on the 19th pass and the reason why they were street gears and not Pro Gears which i put in and are still in that rear.
Also told a big car, big cube combo is not as good as a light car, small cube (small block Camaro's make up a bulk of H & I Stock) but I did run 7-8 tenths under.
ID:	19917   Click image for larger version
ID:	19918   Click image for larger version
Old 07-06-2013, 11:44 AM   #2
impstocker
impstocker's Avatar
Default Re: 1965 Impala BBC Stocker Update
Here are updated photos. Starting body work with 1/4 panels and new trunk floor. Need something to put battery and fuel cell on!
ID:	19921   Click image for larger version
ID:	19922   Click image for larger version
Old 07-06-2013, 11:48 AM   #3
impstocker
impstocker's Avatar
Here is gusset work started on the frame. This is how a big chevy lives without part breakage. The rear upper control arms crossmember is the most important to fix. The rear tends to pull them out if not strengthen.
Old 07-06-2013, 11:59 AM   #4
Billy Nees
Liked 7,779 Times in 1,742 Posts
Wil, thanks for the pics! I'm enjoying this, I just love those BB cars.
Billy Nees 1188 STK, SS
Old 07-06-2013, 01:55 PM   #5
Thanks, Wil
How about a similar setup on the uppers, after re-welding of course ?
Love those big cars too.
I started out racing Stock with a 63 Grand Prix, 421 /370 tri-power..4.56's
Right to the floor..6 grand on the line ... even with tires from the 60's
Old 07-07-2013, 12:40 AM   #6
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Will;
Where do you live.
My car is in jersey shore, pa
D
Mark:
Wow that would be a great car to bring back to Stock.
D
Old 08-03-2015, 10:30 PM   #7
impstocker
impstocker's Avatar
Want to thank everybody for the input about the Small Block combos for the 1965 Impala. I will be running my 396/325 engine, this is the same motor that pushed my 68 Impala to 11.70's with a stick at 4095 lbs in I/S I never really sorted out the clutch and 60 foot times, spun the tires a lot. I hope with the TH350 , which I have with a 2.75 1st gear, i can run a consistent lower 60 ft times, my best if I remember were 1.59- 1.65 with the stick.
Lots of real fast I/SA cars in Div. 1 Most SBC Camaros, Novas Chevelles. 11.40 - 11.65 the norm. Yikes! With my MPH I had though the 396 is making power... we shall see. But, more work to do/
Will Lamprecht
Old 11-02-2015, 07:40 AM   #8
impstocker
impstocker's Avatar
Just a quick update. I compound buff paintjob, installed most trim, just waiting for missing pieces. Finishing up brakes, elrctrical ect. Carpet coming in next week to finish off interior. Will be installing a BBC block to mock up for tranny install. Making car ready just to install motor probaly in early next year by Feb.
Will Lamprecht Div 1 65 Impala 396/325 I/SA in progress
ID:	31567   Click image for larger version
ID:	31568   Click image for larger version
Old 11-09-2015, 10:24 AM   #9
OLD INJUN
Question Re: 1965 Impala BBC Stocker Update
Originally Posted by impstocker View Post
just a quick update. I compound buff paintjob, installed most trim, just waiting for missing pieces. Finishing up brakes, elrctrical ect. Carpet coming in next week to finish off interior. Will be installing a bbc block to mock up for tranny install. Making car ready just to install motor probaly in early next year by feb.
Will lamprecht div 1 65 impala 396/325 i/sa in progress
how does that new drivers door latch work?
OLD INJUN is offline   Reply With Quote
Old 11-09-2015, 11:58 AM   #10
impstocker
impstocker's Avatar
Latch works allright for a nock off Mexican/Chinese piece. This ain't no 100% original restoration show car, just look good from the stands i guess!
Will Lamprecht I/SA 65 Impala in progress
