Old 12-27-2014, 04:29 PM   #101
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: 1967 Fairlane Super Stock
Wish my junk would turn out that nice. Did you put any flat panels on the floor before carpeting the rear area, or just form/glue the carpet on the factory floor pan?
Rich Taylor
I/SA - 321
Old 12-27-2014, 06:30 PM   #102
Rusty Gillis
Rusty Gillis's Avatar
Liked 87 Times in 19 Posts
It was just glued to the factory floor.
Rusty Gillis
Former NHRA SS/FA and SS/GA record holder
Rusty Gillis is offline   Reply With Quote
Old 12-28-2014, 02:01 PM   #103
Tom Meyer
Liked 354 Times in 120 Posts
Great Build Rusty, I hope mine turns out as good as yours. A quick note that your shoulder straps are just wrapped around the pipe behind the seat, I think that they have to be mounted so then will not slide from side to side. Tom
Tom Meyer 5240 SS Stock ???
Old 01-19-2015, 11:08 AM   #104
Rusty Gillis
After a lot of thinking and studying the NHRA classification guide I have decided to build a 302 from a 1968 Cougar and race it in GT/LA. It is rated at 230 hp and I can run aftermarket aluminum heads along with the same Quick Fuel carb that is the legal replacement for a 390 or 428CJ. This will be new for me because I only have experience with the FE motors. I believe it will be a lot cheaper to build than an FE and very competitive.
Rusty Gillis
Old 01-19-2015, 03:49 PM   #105
my69396
Liked 46 Times in 20 Posts
I would check the carb again. I think it takes the small carb.
my69396 is offline   Reply With Quote
Old 01-19-2015, 05:15 PM   #106
Rusty Gillis
I checked with NHRA and they said it was legal on the 230 HP 302 in the 1968 Cougar. It came with the same size Holley as the 390 so it is legal. I also found out I can't run the hood unless the engine has ram air.
Rusty Gillis
Old 01-19-2015, 07:09 PM   #107
Dave Turner
Dave Turner's Avatar
Liked 364 Times in 138 Posts
I think the acceptable Quick Fuel carb is the SSR-585-VS.
Dave Turner
SS/GT #1153
Old 01-20-2015, 12:11 AM   #108
Rusty Gillis
The replacement carb for the Holley on the 390 is SSR-780-VS. The Holley on the 230 hp 1968 Cougar is the same size as the 390 Holley so it is a legal replacement according to the email I got from NHRA.
Rusty Gillis
Old 01-20-2015, 12:50 AM   #109
Dave Turner
An email from NHRA should be enough documentation to get you by..... just seems odd that the same size carb is approved for use on displacements from 302 to 428 cu. In.
Dave Turner
SS/GT #1153
Old 01-20-2015, 03:22 AM   #110
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
HP Disp C.R. Ind. Make Model/Transmission Manifold R.R. Lifter Head cc Notes
230 302 10.0 1-4 Holl C8OF-D/SM, C8ZF-B/AUTO C8ZE-A 1.60 H 49.50 15
325 390 10.5 1-4 Ford C8OF-C/SM, D/AUTO C8AE-A,D 1.73 H 63.50 12
12 – Holley (4452) 1500x1500/1093x1093 Holley (3793,3795,3796) 1563x1563/1250x1313
15 – 1563x1563/1250x1313
Sorry its bunched up but this is copied from the Engine Blueprint Guide. The bold sizes, straight from my Holley book are for a "600" cfm carb. The "780" was used on the 335 HP 428 ci in the Mustang, Fairlane & Cougar. The last update in that year was #16 for an ALT Manifold.
Dave Noll, EF/S ,?/SA 6526
