Old 04-09-2008, 12:27 PM   #101
Dick Butler
Liked 32 Times in 19 Posts
Default Re: Automatic Horsepower Factoring System
One of the problems is there is nothing to gain by running FULL out. No big prizes, No one in class to beat.Maybe this is the time to re mention there are too manyClasses allowing people to HIDE bogus combos from the AHFS.
IF classes were condensed to 1/2 the current number this would put people together. If MONEY were at stake for class or heads up in eliminator occurred more often this would PUSH people into running full out THEN more accurate idea of potential performance would be shown. This would work with current AHFS.(Still needs et changed DOWN)(and INDEX changes)
MAKE CLASS a challenge and a goal for people to appreciate winning again and it will help. Speed up the hp change by AHFS but allow soft changes to continue to not over do the adjusting. Consider corrected altitude figures.
Old 04-09-2008, 12:30 PM   #102
Ron Ortiz
Ron Ortiz's Avatar
Liked 317 Times in 103 Posts
Forget the trigger, eliminate it. Let fast cars go fast, it's up th the sanctioning body to take a look at who might need it, randomly. They already do it.
If you want to see how fast they really are just record all the incremental times. If your going to sand bag then you're going to have to do it the entire run.
Incremental times will fix this mess real fast.
Ron Ortiz
U/SA tick tock
Ron Ortiz 2102 STK
Ron Ortiz is offline   Reply With Quote
Old 04-09-2008, 01:19 PM   #103
SSDiv6
Good 'Ol Farmer, in the early days, had his own computer handy for factoring... an ET vs Weight slide rule style calculator...probably a Moroso brand
Old 04-09-2008, 05:24 PM   #104
SS Engine Guy
Originally Posted by lca1971 View Post
SS Engine Guy,
. I saw in one of your post that you wanted to allow boosted cars in the mix! To bring in youner guy's.
Nope, wasn't me.
SS Engine Guy is offline   Reply With Quote
Old 04-10-2008, 12:37 AM   #105
lca1971
lca1971's Avatar
Liked 3 Times in 2 Posts
Sorry for the mistake!
Chris
lca1971 is offline   Reply With Quote
Old 04-10-2008, 10:46 AM   #106
Lynn A McCarty
Lynn A McCarty's Avatar
This method would work, but you cant penalize a guy for going fast. You should only penalize an engine if the average of everyone using that combo goes fast. For example, if the 10 slowest guys go 3 tenths faster than the 10 slowest guys of another combo, then that tells you more. Looking at one engine with a trigger method destroys class racing.
It tells you nothing unless you consider the air quality. He also needed a weather station.
Lynn A McCarty 3470 SS
Lynn A McCarty is offline   Reply With Quote
Old 04-10-2008, 11:29 AM   #107
SSDiv6
Lynn, many of us remember they way farnmer did things...although many times it was not pretty, he seemed fair and there was not the issues we have today with the factoring. Do not get me wrong, with all the new technology and science today, the problem can be solved with a computer program.
