Old 03-20-2019, 01:00 PM   #1041
Nmbr1GMfan
Default Re: H-I-J '76 Nova re-fit.
Originally Posted by Tim H View Post
Yup, I noticed that "1/2 +" as quoted and like the 3/8" measurement personally. Really feel for you and Autumn, such rotten luck on a very straightforward engine build. SBC oiling at this approximate power level should be bulletproof as it comes from GM.
I have some theories, but won't know till I get there and start looking further. I'll recheck the pick-up but I'm pretty sure with the 1 piece gasket it was 1/2".
Todd Greene
Old 03-20-2019, 02:05 PM   #1042
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
The little plug I mentioned is down in the block under the rear cap. It presses in there and closes off an oil passage. You'd still have oil pressure even with it missing.
A good shop would knock that plug out to boil the block and sometimes it never got replaced.
A high oil level in a stock depth low capacity pan is not a good idea but with a windage tray it should not have caused this.
The pickup being slightly higher than ideal is not a big deal to me either.....unless oil is trapped up top and you generally will see oil pressure fluctuations if the level was to low and pump was starving.....
Think about just how the oil in the pan is moving around in a wheelstanding car....sitting on a dyno its not under any of those forces....
Small blocks "like" to kill #5 & #6 rods more than any others.....Don't ask me why …..
I hope you find a cause and hate seeing stuff like this....but it happens unfortunately.....
Rich Biebel
S/C 1479
Stock 147R
Old 03-20-2019, 03:44 PM   #1043
lareagle
Liked 26 Times in 12 Posts
What are you running for oil filter, can't see in your pictures on dyno.
Need to be a racing filter. Have see racers have trouble with regular street filters.
Larry
lareagle is offline   Reply With Quote
Old 03-20-2019, 09:56 PM   #1044
Nmbr1GMfan
I put the plug back in under the rear cap, it's there for sure.
Todd Greene
Old 03-20-2019, 09:58 PM   #1045
Nmbr1GMfan
Larry
NAPA gold 1061
Todd Greene
Old 03-20-2019, 10:02 PM   #1046
Nmbr1GMfan
Square 1, we're back.
Todd Greene
Old 03-20-2019, 10:35 PM   #1047
Dissident
Liked 73 Times in 36 Posts
Todd and Autumn,
Sorry to hear of your engine problems on the dyno.
Might want to check a few things in the oiling path.
A) oil pump pressure relief valve piston to bore. If it sticks open the oil is returned to the sump and kills oil flow to passages.
B) oil filter adapter bypass should be sealed off. IF open it returns oil to sump and supplies unfiltered oil to engine.
C) Plug under rear cap does the same as B) above.
Good Luck on finding the offending issues so you can continue.
D) all the above depends on a properly clearance pump and often out of the box, they are far from it. Although that is probably not the problem, good time to check it.
Hang in there!
Regards,
HB2
Dissident
Dissident is offline   Reply With Quote
Old 03-21-2019, 07:30 AM   #1048
Rich Biebel
Originally Posted by Nmbr1GMfan View Post
NAPA gold 1061
Nothing wrong with using a 1061...…
That filter has no anti drain back valve and is fine mounted vertically.
A 1060 does have the anti drain back flapper valve.....needed for filters mounted horizontally....
Wix makes Napa filters and they just add a 5 to the number to denote its an oil filter.....
51061 R is their racing oil filter....and I use those...and have used them for years with no problems.....
The only filters I know of that had issues was Fram…..and I saw it first hand and won't use one even on my road vehicles.....
Rich Biebel
S/C 1479
Stock 147R
Old 03-21-2019, 07:22 PM   #1049
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
Originally Posted by Glenn Briglio View Post
What bearing clearance and how was it measured?
how much trash did that produce in the oil filter ?
Old 03-21-2019, 07:24 PM   #1050
gmonde
gmonde's Avatar
Cam looks good, rod bearings... not so much.
