Liked 3 Times in 2 Posts
I can not thank you guys enough for all your help.
My new Engine builder, actually has a old SS motor sitting there he is going to put in my car for me to use till we get mine right. He loves S/SS racing and asked me if I would mind running one of the Gt classes this year instead of S/ST. If I did my math right our 89 GT with a 68 302 4bbl motor should fall into GT/MA. He is also sending out my converter to make it work with his engine. Otherwise he said the car should work fine. I am in the process of changing out the front cross member and a arms now, otherwise the car should be fine. He is positive we can get at least .10 under the index, to start with at least. I tiold him as long as I can at least be close to the index for the first try I dont care. I am not looking to go out and set records or nothing just want to be able to race, and have fun. Best time I ever had racing was driving a friend of mines old 68 camaro SS/FM car back in the late 80's, we even won class once it was just cool.
NHRA: Comp 2200 - S/C 2201 NMRA 2012 Outlaw 10.5 #10 |
Liked 4 Times in 1 Post
Freddie, if your serious about super stock, get ahold of SSSSA and race with them. I am building a stocker and this is where I will play before hitting div. races. I'm about 45 minutes from Tampa, outside of Dade City, just off of 98, close to Trilby and Ridge Manor. STOCKERS RULE!!!!!!!!!!!!!!!!!!!! Rick.
Liked 70 Times in 29 Posts
If you are going to try to run SS, the QA1 front end ( I assume you mean K-member) will have to go. Make sure the interior isn't gutted either. You have to keep the dash, door panels, interior trim, etc.
Like these other guys said, use a good C-4 with a low first gear.
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
Chris, yes the K-Member and the lower control arms are being changed back to stock. I never gutted all the interior out of the car, we tastfully lightened certain areas, but retained the dash, door panels, and all interior components. I just have to carpet the rear seat area and the trunk area of the car. I think I am going to put in a new headliner as well, mine is kinda dirty and burnt a few holes in it adding to the cage.
My next question would be what kind of stuff should I plan on packing in the trailer to race at a divisional event? should I plan on being torn down simply because its a new car? I usually carry a set of intake gaskets and header gaskets anyway, but should I grab a set of head gaskets and pan set as well?
