Liked 53 Times in 28 Posts
But it IS bracket racing
__________________ Unless you have a heads-up. These are not big motor, big tired cars on alcohol with a power glide trans. They are heavy with loose converters with too small of a tire,not enough carb,nasty little camshafts. I race both and have won in both. Both of them are challenging, but they are different. |
Liked 759 Times in 379 Posts
a heads up that the vast majority of stock racers look to avoid, playing the ladder, hoping to avoid a heads up race in the 1st round, early rounds, counting on another class racer ending the fast guy?s day in a handicapped start with shoe polish on his window. Again it IS bracket racing and while I’m stating the TRUTH again, I’ll continue by also stating many of the fast guys are just fast guys that don’t have the skills at either end of the track so they are an easy win for drivers that do have the skills.
Liked 1,463 Times in 307 Posts
As Stock/SuperStock Racers, we have some confessing to do. We are not
Semi- Professional Sportsman Racers. Regardless of investment, Engine, Transmission, or Differential R & D research we do, no, we don't cut it. Thinking we have made life long friends through our racing, Sorry, not allowed, we are supposed to have enough friends, no new friends allowed, NO FRIENDS FOR YOU, TWO YEARS, As a famous Food **** once said. We are not having fun, we should be ashamed we are in these Classes. DO NOT pretend we having qualifying, Heads UP Races, that some peoples goals are having a fast car, some like consistent cars, others like their cars to be show quality. These preferences will know longer be allowed, as outlined in the new 2025 Rule Book- Racing **** Rulebook, to be published soon. Anybody appearing to be doing R&D, going far under their index, Winning Class, or generally having fun, will be suspended for up to 2 Years, and fines depending on level of enjoyment you appear to be having. No Appeals allowed, as you are not as smart as publisher of new rules, so why waste time in a battle of brains, when we are just not worthy. J.R. |
So what part of the TRUTH and the FACTS didn’t you like that fueled your unhinged rant about your fellow stock/super stock racers?
#5 | |
Liked 1,169 Times in 331 Posts
Dawson Pauley #2827 N/SA 1980 Malibu SW 2S 305/180 #2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide |
#6 | |
When you threw out the 40k number, you said nothing about competing for big money. You said "Meanwhile bracket cars today cost around $40k on the low end to $175k on the high end....Nothing cheap about bracket racing today either." Nothing about that sentence indicates the caveat.
Dawson, just an fyi, I bracket raced with a QJet carb atop the 396 and later the 454 in my Chevelle for 8 years and manually shifted the 3 speed trans in my Chevellle for the entire time I raced it, over 3000 passes, with the stock “staple” shifter, no gates, nothing to prevent the shifter from going from 1st gear to neutral, winning a lot of rounds and races, as well I manually shifted the 3 speed trans in my Firebird from the 1st pass in it back in 2008 and through 2018, again thousands of passes. Both cars were easy to drive, it was not challenging nor was it difficult to tune my Q Jet and predict its ET’s and neither had a 2 step. Maybe I’m a better tuner and more coordinated than some running stock eliminator.
![]() Well now I’ve clarified my statement about bracket cars for you but surely you knew I wasn’t taking about taking mom’s daily driver to a Friday night trophy race. Last edited by 1320racer; 02-05-2025 at 04:05 PM. |
Did they also have stock heads, intake, valve lift, flat tappet lifters, bore, stroke?
Also you don't run those combos now, why change if it was so easy? The tried and true formula for bracket racing is a 4bbl carb, transbrake, glide, aftermarket engine, big tires and methanol. 0 of that is common or legal in stock lol (unless it came with the right carb from the factory, all combos vary). You may have found consistency and success with it in the past, but you can't argue it is the most effective way to bracket race. Otherwise 99% of accomplished bracket racers are doing it wrong lol.
My Chevelle was always more stock than maybe any stocker in the country!, right up to the day I sold it in 2008. Yes stock heads, manifold, carb etc. back in the day when I made my 1st pass in it running 15.34 at almost 4100 lbs. through full factory exhaust with exhaust manifolds and through 1999 IIRC and running in the 12’s
I sold it because I had run quicker and faster than I ever had plan to with it and didn’t want to cut up a real stocker that also weighed nearly 3900 lbs. to be legal as well as safe to run consistency deep in the 9s as it was capable of. Last edited by 1320racer; 02-05-2025 at 04:16 PM. |
#10 | |
Jared Jordan 9 B/SA 2024 Jeg's D7 All Star - Stock |
