Old 07-27-2024, 08:59 PM   #1
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Red face Re: Metric T-200 issue
Adding fluid did not help
2-3 flare is really excessive and is clearly visible on both the recall tach and datalog from the ECU
I will do more investigation this week to verify the fluid level and the shifter, cable and detent adjustments but I think this trans needs to be gone thru by someone that does them and knows what their doing
Like I said earlier, the men doing them are few and far between....
Rich Biebel
S/C 1479
Stock 147R
Old 07-28-2024, 07:02 PM   #2
SS3860
Liked 170 Times in 56 Posts
Default Re: Metric T-200 issue
Rich, I run a metric 200 built by Thomas Arnett. It has the deep cast aluminum pan and takes 8 quarts to fill with the correct dip stick and tube. Cooler lines are plugged also.
Tom Flowers
E/SA 3860
SS3860 is offline   Reply With Quote
Old 07-28-2024, 07:34 PM   #3
Tim Barrett
Liked 472 Times in 72 Posts
I had a similar issue several years ago with my Sepanic Metric 200. It was suggested that I shift it into 3rd gear and pull the shifter linkage pin out of the lever on the transmission. When I did I couldn't get the pin back into the lever. I had adjusted the shifter linkage with the transmission in park,,not in 3rd gear. Linkage adjustment is more critical for 1st 2nd and 3rd gear,,especially in 3rd. Never had slippage again going into 3rd.
Glad to see you back!!
Tim Barrett is offline   Reply With Quote
Old 08-25-2024, 07:38 AM   #4
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Originally Posted by Rich Biebel View Post
I think this trans needs to be gone thru by someone that does them and knows what their doing..
As you stated a month ago
Old 08-25-2024, 10:18 AM   #5
Rich Biebel
Yes I did and I also said T-200 trans builders are few and far between
That?s the main problem, you aren?t going to be able to get one done in any short time going by what users tell me.
I was hoping for a better outcome but knew i was probably treading water
The way I?ve been driving along with how erratic the car is, a better trans isn?t gonna turn on any lamps
Gotta lot to do before that could happen
Rich Biebel
S/C 1479
Stock 147R
Old 08-25-2024, 10:22 AM   #6
L.Fite
Liked 497 Times in 243 Posts
Allways with the negative waves...
L.Fite is offline   Reply With Quote
