Liked 226 Times in 74 Posts
Where are you guys mounting your ignition boxes on your Stockers? Just looking for ideas. Thank you
Liked 685 Times in 196 Posts
I’ve seen a lot of Chevy’s in the passenger footwell. Probably goes with the shorter wiring and don’t get it wet comments. I have a Ford and I think it’s going under the hood when I mount it but like you I’m open for ideas?
Also check out Bobby Fazio video interviews where he shows the interior, under hood and in the truck of a lot of cars, some good stuff there!
Mike 7570 A/SA Last edited by Mike Gray; 09-11-2023 at 11:36 PM. Reason: Added |
Liked 5,109 Times in 1,947 Posts
"We are lucky we don't get as much Government as we pay for." Will Rogers Last edited by Mark Yacavone; 09-18-2023 at 12:11 PM. |
Liked 2,465 Times in 695 Posts
Our mopars are mounted behind the glove box
or right below in that general area.
#5 | |
Liked 520 Times in 176 Posts
I mounted my MSD on the passenger side toe board. Mostly because its convenient in case I have to service it. MSD recommends that the box/ ignition controls be placed where air can move around it and cool it. That's why they don't recommend putting it a "glove box" or enclosed location. Respectfully, Henry Kunz 1534 H/SA |
Behind our Glove box door there is no longer a real actual
glove box or a heater box. It is totally open to air flow. Sorry I was not clearer. It is protected from weather inside car and some of outside heat out is mitigated a bit as we live in Nevada.
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 09-18-2023 at 02:44 PM. |
Liked 43 Times in 14 Posts
IMHO, I put mine on the passenger side underneath the glove box on a hinged panel. Relay switch panel on the topside with all race-related wiring - MSD components on the underside. Coil mounted on the inside of the firewall just above the hinged panel.
Hinged panel allows for easy access while keeping it out of the way when racing. MSD on the underside allows easy access to MSD box settings and RPM chips (if you use them).
Dave White NHRA Stock/SS 606 |
#8 | |
Mike 7570 A/SA |
![]() I can barely afford myself :-) All for the love of the hobby
#10 | |
Liked 226 Times in 76 Posts
https://www.classracer.com/classforu...7&postcount=84
Andy Friar |
