Old 08-18-2023, 01:35 PM   #1
john ancona
john ancona's Avatar
Liked 187 Times in 58 Posts
Default Re: Roller Cams in Stock Eliminator?
Originally Posted by Bill Grubbs View Post
Not calling you out, but John you don't speak for me either.
JMHO...Keep Stock...Stock!
While we cannot undo past changes... we do have the ability to stop future changes!
As far as lifters are concerned, we toasted a SS engine first rnd of qualifying at Denver. We had a lifter go bad and take out a camshaft. The full extent of the damage has yet to be determined. At best it is a lifter, a reground cam, and a pushrod. At worst...we shall see.
This was a $$$$ lifter. **** Happens. We have not had a stocker lifter go bad since 2007 (knock, knock, knock...knock on wood) and that was a Schubeck lifter which exploded on startup. We have now had two roller lifters go bad in the last 5 years. If your having lifter issues, then fix the issue...don't change the rules! We found our issue for the first SS failure...it was an issue put in place by a now closed engine builder in the Houston, Texas area. The current issue appears to me to be a bearing failure. we will determine whether it is a material failure, or if the failure was caused by some other issue within the engine. Either way, I have complete confidence any future failure will not be for the same reason.
I do not believe in the concept of "One person ****s their pants...everybody wears diapers!"
Some how you ,and others think I am speaking for all of Stock Eliminator when in fact as I said on the site many times there are those of us in my circle of friends of witch you and others last time I checked are not included , look I run stock ,and super stock
so there is no need to say I am trying to change Stock as I am in the crowed that voiced my opinion many times over the years right to NHRA at Pomona in person with many others about all the changes over many years with that said ,I have yet to hear any body say oh we will remove any of the changes on my car up to this point ,but there are those on here that are quick to say keep Stock Stock that have all the changes on there cars
John Ancona 717 STK / SS
john ancona is offline   Reply With Quote
