Got the gauges picked out I think for the dash project. . I downloaded the ones I want off the net, sized em' to the specs on the site & printed the faces out on the printer. Then I cut some PVC gauge housings on the CNC. They are a little deeper than the actual gauges but that'll insure I have ample room for the real deals down the road. Now I can make a bezel. That outta' keep me busy for awhile.
![]() Cut the bezel out on the CNC. There's a bunch of steps to get this thing cut. I keep thinkin' one BooBoo & it's scrap. :shock: ![]() Got the bezel off the table. Now comes the task of bending it in the right places & at the correct angles to fit the dash. ![]() Got it roughed into the dash cover. Still rough but close enough that I know it will fit. The right wing is 1/2" longer than the left wing, so angles are different. I think I got it purdy' close though. Next is to cut the contour in the fiberglass for the oversized tach & speedo. {that's a relief} ![]() ![]() ![]() |
Got a little further on the dash today. I made plugs out of PVC to form the gauge wells, since these gauges are too big for the original bezel opening.
![]() I did the kitty hair "form the bezel to the dash deal" again. Used vinyl & spray Pam as a release agent. ![]() One last big hurtle for me. TIG welding on the bezel w/o ruining it. I welded some strap aluminum to the top & bottom to stiffen up the bezel & to provide a place for rubber mounting grommets. ![]() Got the bezel just setting in place. It's being held in by the dash bar. Close enough to see what it'll look like. ![]() |
very nice work...
go into business for yourself and sale one to me. i got a 79 camaro it would look great. the cost of gauges would be preety high to. but, hell if you had to ask how much you should not be here.
S/ST 1739 Carlos Mendes |
If I told you how many hours I had in that thing you would laugh.....
Liked 1,876 Times in 577 Posts
man, that does look good, nice to see someone take pride in their work.
Thanks Keith
That is a super job. I wish I had that talent. If I can't make it with Duct tape and J B Weld then I'mn toast.
Thanks CPOlesen
Got the bearing housing for the steering column (firewall) done this weekend. Now all I need are those back ordered steering column parts.
![]() ![]() I got one last thing done this weekend. I pulled the old dash out & used the glove box as a plug to make this mold. Got a couple little places to touch up and then I can make up a couple fiberglass glove boxes to finish off around the intercooler. The door has that imitation leather pattern, & the Camaro logo. They came out O.K. so far. ![]() |
Little steering column mock-up tonight. The Mark Williams quick release hub came today.
