Liked 99 Times in 60 Posts
This will be the mildest, least expensive build I have done in many years. The core is a 2010 Chevy Colorado "donated" to the cause
![]() The novice has at least two meanings. First, my grandchildren will be driving it, and they qualify as novices. Second, my goal is to show the build-up with basic tools and supplies to demonstrate that an inexperienced builder can be successful. Would you please check back often as the project develops? Photos and details beginning soon.
Larry Woodfin 471W Last edited by Dragsinger; 07-20-2021 at 08:20 AM. Reason: name change |
The plan is to use as many bolt-on parts as possible without cutting or modification. CalTracs, 29.5 x 10.5 radial, steel wheels, all OE sheet metal, bench seat. Conventional first-gen SBC, powerglide, 12 bolt rear narrowed as needed.
Larry Woodfin 471W |
Plus, an old set of Lee Sheppard ported Turbo heads
Working on a truck is a beautiful thing! Remove the bed, complete access to modifying the rear suspension. After a time of thought, I plan to install a set of ladder bars. They will do everything I want in this situation. I will also install them about 4" inboard of the factory frame so that if in the future I want a larger tire it will be an easy upgrade. Installing a Chevy 12 bolt will also be part of this exercise.
Here she is on my trusty, home-built tables that allow placing components at ride height and allowing a good view of the fitment.
Some notes, as I begin this project, I recognize the Colorado/Canyon as a good package. It has a full-frame, rack and pinion steering, coil-over front spring with a-arms, it is overall about 3" wider and 3" longer than the S-10. I expect it to be a very nice footbraker.
In the first photo, the front springs are removed so the suspension can be blocked at ride height.
The second photo shows the chassis blocked at one degree forward rake. The third photo shows the chassis blocked level.
For safety reasons, I would reconsider the use of a bench seat. Install some racing seats and give the kids additional safety margin.
When converting a factory stock truck to a drag race truck, it is necessary to turn all bolts anti-clockwise. Later, after modifying each piece, bolts can be turned clockwise.
Jake, it is a footbrake [bottom bulb] bracket racer.
