Old 02-24-2021, 08:29 PM   #6
1matcoman
1matcoman's Avatar
Liked 350 Times in 134 Posts
Default Re: Tire pump for the RV tires
Originally Posted by FED 387 View Post
The pancake compressor is not going to do the job!!! First the recovery rate is going to take too long (2.3CFM)and the upper limit of them is only about 150 PSI-- it will take you forever to do anything .---Are you talking 22.5 TRUCK tires like on a Diesel Pusher MH or tires on a Class A or Class C that take 90-100 PSI ????----you are going to need a Compressor !!!!! not a flyweight pancake unit-- Save your money on this--FED 387
FED,
While I will admit that this is not the ideal way to add air to a 22.5 motorhome and/or truck tire, it will most definitely do the job. I have seen it dozens if not hundreds of times. I don't see to many motorhomes with enough room to carry a large compressor, so these little portable units work just fine.
