Liked 2,493 Times in 700 Posts
The tire height makes a significant difference in reaction time.
5 or 10 Lbs pressure in the tire = very little that I can find. Maybe if I took the front runners from 40 to 10 it might make a observable difference. Someone can tell me = I am not going to try it! My Blood Sugar level makes a lot more difference = Of Course - I am old!
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 10-13-2020 at 07:16 PM. |
Liked 805 Times in 245 Posts
I'm not sure of the exact height of the stage beam but as an experiment, I put a 3" tall block in front and behind my 26" tall tire, the measurement at 40 PSI and 10 PSI was exactly the same. Based on that, I think the change in reaction time is a mental thing and not real.
Jim Caughlin SS 6019 |
Liked 239 Times in 90 Posts
[QUOTE=GTX JOHN
My Blood Sugar level makes a lot more difference = Of Course - I am old![/QUOTE] From a fellow diabetic..... yes it does. I keep good check on mine because it makes a HUGE difference in react and driving the stripe. I check my tires in the morning and thats about it lol. 38frt & 19rear is my bracket tune Rpms will change react the most, mine is 200 for .010 up to a certain point Last edited by jamie2370; 10-15-2020 at 04:24 PM. Reason: ADDED |
Liked 4 Times in 2 Posts
Many different opinions from many great drivers but in my personal opinion I don’t feel front tire pressure is very important. I normally don’t check front tires after I leave the house unless one or both look like they’re leaking for some reason. And pretty similar with rear tires. I’ll usually check them every morning as they can vary quite a bit with outside temperature. And sometimes I’ll give them a check to make sure they’re about the same throughout the day. But whatever works for you or makes you feel most confident and comfortable is what’s most important!
We check all four each morning and the rear
most times in the staging lane unless we are rushed.
#6 | |
Liked 431 Times in 224 Posts
With the dragster I pay a little more attention and check before each pass, but I buy the cheapest gauge that is in the range needed.
S/ST 51 S/C 53 |
I check mine every run. I`ve seen front tire pressure drop 2 to 3 pounds after the sun drops. Same scenario during the day as it gets warmer. Do the same with both my V6 Stocker and 11 second S/P car.
Lane Weber It`s Not What You Drive That Wins....It`s How You Drive It |
Liked 57 Times in 24 Posts
Well I didn't get to try anything at Indy today.
We had a tire hooking problem. Like eye to the sky problem.On 2nd pass tried to Kill some power,took 14 degrees out at the start line and dropped the 2 step 400 rpm. Then I keep my foot in it. Hung the front end way up. Busted the pass Side shock and think it messed the top ball joint up. Loaded up and went back home To say Indy was hooking today was a under statement. Hope someone got a good picture. Lol David |
