#1 | |
Liked 800 Times in 237 Posts
The oil deal is a bigger issue for Stockers that have to use a flat tappet camshaft combined with high spring pressures and aggressive lobe profiles. For those not running under that set of rule constraints, there are dozens of oils that will work well. Excessive additive precipitation is something to consider when choosing an oil filter. Those dots can be connected accordingly. ![]()
"That'll never work....." |
#2 | |
Liked 138 Times in 51 Posts
Valvoline says that straight weight oils are usually recommended for smaller and older engines. 5th question down: https://www.valvoline.com/about-us/f...-viscosity-faq
LOCOMOTION Racing |
#3 | |
Liked 7 Times in 6 Posts
Liked 880 Times in 311 Posts
This is a little off topic... but still oil related...
I've been hearing of some guys finding power on the dyno using some of the new oils designed for older Hi mileage engines. They say it is because the rings seal better. Anyone have any experience with that?
Adger Smith (Former SS) |
