Old 05-11-2017, 02:17 PM   #1
Adub464Q
Adub464Q's Avatar
Liked 478 Times in 91 Posts
Default Re: Rd #3 Stock @ Atlanta
Does anybody remember what happened at the Fall Charlotte race last year?
First Round, Stock
L: Jeff Warren Dial 10.38
R: John Leach Dial 10.52
The tree dropped as it should, but when they got to the finish line, the system had this on the screen.
L: John Leach, Dial 11.40
R: Jeff Warren, Dial 10.52
It had swapped the lanes info as well as switched a dial-in on the left lane to read index. They did re-run this pair. Weird occurrence, until the same thing happened at a bracket race near me a couple months prior to this.
Compulink will always be susceptible to glitches, so even if the scoreboards read correctly, the system may throw you a curveball. Everyone pay attention to the boards and the timeslip.
This round is still on All Access on the Fall Charlotte coverage, under Saturday, around the 46-47 minute mark.
Austin Williams
3 SG
464Q STK SC
Adub464Q is offline   Reply With Quote
Old 05-11-2017, 03:26 PM   #2
Ron Ortiz
Ron Ortiz's Avatar
Liked 317 Times in 103 Posts
Any racer out there who has had something go array with the dial in, has always checked their dial in before they have staged after that incident. If they haven't had it happen to them yet, it will. Then they will check the dial in after that.
Like it has been said on here before, "it is the drivers responsibility".Personally, I can't believe Jim let this happen for as long as he has been racing. Then, maybe, he has never had a dial in problem before. If that is the case, he won't do it again.
As a side note, if you dial in improperly, your fault, no rerun and you are DQ'd, no matter what the run resulted in. Just the way it is. Lets not make this more complicated.
Ron Ortiz
U/SA dialed and ready to go.
Ron Ortiz 2102 STK
Ron Ortiz is offline   Reply With Quote
