Liked 56 Times in 29 Posts
I agree with the above advice. When I read the initial post, I felt the carb was too big, the intake too aligned to high rpm (especially depending on how it was ported), and the rear gears too mild. Yes, the carb and intake may match the ported heads, but the overall result is consistent with a high rpm combination, and is being killed by a low rpm combination elsewhere.
Liked 364 Times in 138 Posts
How much total timing do you have dialed-in....all in by??
Dave Turner SS/GT #1153 |
Liked 7 Times in 5 Posts
How tall are your rear tires?
3.90s wouldn't be bad if you had 26-27 inch tire i've been mid 1.50s in a 3200lb amx with 4.10s and 28 inch tires with a much milder than your combo 390. that 1.90 sixty foot definitely indicates a issue somewhere. |
Let me know when you find that spot on the tree,lol.
HAMMER |
