Old 03-15-2015, 11:32 AM   #1
Jim Parsons
Liked 195 Times in 30 Posts
Default Article in ND on Jon Jamison’s SS Chevelle
Nice story in latest National Dragster on Jon's Chevelle SS wagon.
Didn't know you could run 12 bolt gears in Ford housing, very interesting, learn something new every day.
Heck I can remember when about 1/3+ of all S/SS cars were wagons due to the better traction and lower class fit.
Jim Parsons is offline   Reply With Quote
Old 03-15-2015, 12:22 PM   #2
John Kelley
Default Re: Article in ND on Jon Jamison’s SS Chevelle
Perhaps you didn't read the Super Stock rules......"Any OEM type permitted" So any make OEM rear end can be used......
John Kelley is offline   Reply With Quote
Old 03-15-2015, 12:36 PM   #3
Todd Bailey
Liked 31 Times in 16 Posts
John, he is talking about 12 bolt gears INSIDE of a Ford housing. Very interesting as I myself did not know this.
Todd Bailey is offline   Reply With Quote
Old 03-15-2015, 01:10 PM   #4
stocker396
stocker396's Avatar
Liked 58 Times in 16 Posts
Yea that set up has been around awhile. Comp cars are notorious for it. Uses a special 3 member (like a GM55 Style) only 2 pinion bearings instead of 3. Less Drag (like a 12 bolt) more Strength banjo set up(like a 9") best of both!
Tried to get this set up legal for my stocker but they said NOPE! But copos use a 9" I just wanna use the housing it would be GM Gear Type...still said NOPE. If I wanna do it they told me buy a new COPO LOL!!!!
stocker396 is offline   Reply With Quote
Old 03-15-2015, 03:44 PM   #5
John Kelley
That brings back memories...it seems like Rick Houser used that in SS/AA back in the 70's or early 80's....
Old 03-15-2015, 04:17 PM   #6
FED 387
Liked 330 Times in 178 Posts
Yep-- Strange makes em has for about 10 years--- called a 12 bolt drop out--- very light less friction ---not a real good selection of gears tho you are restricted to whatever 12 bolt gears are available-- you need a special case and spool to fit in the Ford 9"- works great in really light cars too---FED 387
Old 03-15-2015, 09:32 PM   #7
Don Anderson
Liked 24 Times in 8 Posts
Talking Re: Article in ND on Jon Jamison’s SS Chevelle
Great story indeed on Jon`s Chevy Wagon !! Lot of good folks behind this ride and a record is in the near future indeed !!
Don Anderson is offline   Reply With Quote
