Old 03-02-2015, 09:35 PM   #1
Kingpen
Liked 64 Times in 22 Posts
Default Re: U/SA help request
You said you ran 8 gauge wire from ign box to power source but ground to the block,I had 2 different boxes in 2 separate cars that gave problems until I grounded box directly to the battery.might be worth a shot......Victor
Kingpen is offline   Reply With Quote
Old 03-02-2015, 07:01 PM   #2
Jeff Stout
Liked 708 Times in 285 Posts
Originally Posted by Bob Gullett View Post
Years ago we had a fuel pump go bad. Had pressure but no volume. Or a plugged fuel filter. It caused us a major performance loss and didn't affect the running of the car. No engine miss or nothing. Changed pump problem cured. Also I've seen where someone is using a cheap brand of synthetic oil causing poor ring seal.
Spent about 1200.00 to find it was the pump. Had gauge mounted in front of windshield and always stayed above 6 lbs. So I chased everything else until I changed pump as someone suggested to do and shazam.
Old 03-07-2015, 09:58 PM   #3
Mike Graham
Liked 341 Times in 67 Posts
The rest of the story. I steal the datalogger out of the SS car and we head to Wildhorse
Pass. When the car leaves the fuel pressure drops to zero and never recovers the rest
of the run. Enough fuel that the car doesn't miss.
The idea of let's not over spend on the fuel system didn't work out. I would have never thought that a 110 gph pump would not be enough for a 225 hp stocker.
So on goes the 400 gph spare for my car. Problem solved. Right back to where the et should be and the car is now consistent.
As a side note. The pro bracket cutoff here is 13.99 and here car won't run that in the heat. So I prep a 1.21 carb thinking that it will pick the car up enough to run 13.99 during the day. That carb picked the car up 6 tenths and almost 6 mph. 13.42 at 98 mph on the first pass.
Mike Graham is offline   Reply With Quote
Old 03-08-2015, 11:06 AM   #4
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Uh-oh, do you mind if I ask if that was a new 110gph pump ? My combo uses a 1.21 carb on a 351c but my Carter pump is rated lower.
Dave Noll, EF/S ,?/SA 6526
Dave Noll is online now   Reply With Quote
Old 03-08-2015, 11:13 AM   #5
Mike Graham
Dave
It was new and it was Carter.
Old 03-08-2015, 12:13 PM   #6
Jeff Stout
Mike now your scaring me. I was hoping 13.90 would be enough in my Olds wagon. Good job.
