Old 02-26-2014, 12:00 PM   #71
FED 387
Liked 333 Times in 180 Posts
Default Re: Header Retention Rule Revision
Signman---Please reread the rules again # 2 is the only option---- #1 no longer a valid way of securing them per NHRA rules---If it has a removable collector it will have it secured by the following means (your choicepick one of the 3) weld/tether/body mount that's it!! FED387
Old 02-26-2014, 02:14 PM   #72
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
Originally Posted by gsa612 View Post
Now there's a grey area in the definition of the clamp and hanger lol..I was thinking of using a 3 1/2" SS t-bolt clamp on the collector,with a piece of metal strapping to the clamp bolt,and the other side bolted/screwed to the floor.I wonder if that would be acceptable?.What a cluster**** NHRA!.
My collectors are bolted to the pri.tubes with a tabs (the old fash.way).I was going to make a "tether" ^^ with a clamp and straps to the floor.Unless I'm misunderstanding the revision,it seems like it would pass?.
Old 02-26-2014, 02:18 PM   #73
prixmoracing
Reread what he said and he is correct, 1: you need to use the current tabs/springs/bolts to secure and then in conjunction with that 2: one of the 3 now allowed options (tether or weld or Bolt/Mechanical fastener to frame)
Unfortunately those with the least amount of common sense are completely unaware of their situation....
prixmoracing is offline   Reply With Quote
Old 02-26-2014, 02:29 PM   #74
jmcarter
jmcarter's Avatar
Liked 3,202 Times in 977 Posts
No, must be approved design. See the NHRA accepted parts list for ones that NHRA has approved.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 02-26-2014, 02:41 PM   #75
FED 387
Prixmo---- you can use bolts/tabs/springs if you WANT to but you MUST use either a 1/2inch stitch welds/NHRA approved tethers/some type of device to bolt the collector to the body---I gaurantee you, you show up without a welded/tethered/or hanger bolted to the body collector you're gonna get bounced
Old 02-26-2014, 02:50 PM   #76
gsa612
gsa612's Avatar
Nhra:
Old 02-26-2014, 02:51 PM   #77
prixmoracing
You are wrong about your if you WANT to use bolt/spring/etc because that is the primary attachment. and that is required. Here is the rule.
"Secure the collectors/stacks with an NHRA-accepted header tether.
· Secure the collectors/stacks with a minimum ½” (half-inch) stitch weld located on each primary tube.
· Secure the collectors/stacks by permanently attaching them to the vehicle body or frame with positive fasteners such that they require tools for removal.
Please keep in mind that the attachment methods listed above are meant to be a secondary method of attachment. All factory attachments, such as springs and/or bolts, must remain in place."
Now slowly reread what both of us said, you need to use the original coupling devices (bolts/springs) and one of the 3 now approved tethering methods. Neither of us said you don't need one of the 3 approved tether methods.
Old 02-26-2014, 02:53 PM   #78
buzzinhalfdozen
Liked 11 Times in 8 Posts
OK getting clearer....clear as mud.C and W racing, OK thanks maybe not considering the tabs and fasteners is where I was getting hung up...I will address this on my car before the first race. Suppose I've got a bit before I have to make a move. Merely the fact that there seems to be so many different interpretations of that 1 paragraph would indicate 1 english may not be everyones first language or...and I'm leaning this way, they could have done a better job on the "clarification". Joe
Joe Buchanan SS/BX 3117
Old 02-26-2014, 07:14 PM   #79
ken robinson
Liked 224 Times in 87 Posts
signman my set up was legal the whole time .....bob too .........wow
Old 02-27-2014, 09:07 AM   #80
Dan Fletcher
Sponsor
Dan Fletcher's Avatar
Liked 1,045 Times in 70 Posts
The clarification didn't clarify much to me. I still have no idea if a normal race car set up consisting of 4 primary tubes with a 4 into 1 collector that has 2 tabs with 1/4" bolts like 90% of us have is eligible for an Advance Auto muffler clamp and hanger.
What I do know is that the Collector Tethers that I ordered came on time and fit perfectly. Fitting perfectly might not sound like much, but I had very specific dimensions with no real margin for error. Moreover, I took them on an airplane with me to Cali, so if they were wrong I was pretty much screwed.
I think this has been the most overblown deal I've ever seen. It's not like they're saying you have to buy new ones every 2 years, it's a one time deal. Mufflers were worth fighting about, this is not, IMO.
Dan Fletcher 1781 STK, SS, COMP, SG, SC
DAN FLETCHER TRAILER SALES
Dan Fletcher is offline   Reply With Quote
