Old 03-10-2011, 09:59 AM   #9
Tom Goldman
Tom Goldman's Avatar
Liked 882 Times in 236 Posts
Default Re: Is there a supreme tech god for Stock and Super/Stock
Originally Posted by Pedigo Perf View Post
Key words in the rulebook are "any" and "only". I personally wouldn't have a problem with the aluminum 3rd members for 9" Ford users, and, so what if it is aftermarket. That's what this industry is driven by....the aftermarket!
But.....if the 2011 Drag Packs can use a Ford 9" does that allow all Mopar racers that option? If Tech is getting spread too thin then maybe they need to pick their battles and start by the using the word "any" a little bit more in the rulebook.
When was the last time someone collected protest money? Just curios.
TP
There is no performance advantage to the aluminum chunk ,other than a few pounds that will have to be made up anyway. ...So why not allow them.
The "9"inch housing some Drag Pak cars are using only utilizes the housing stamping . It has a different mounting flange that accepts the Mopar 8 3/4" aluminum chunk [good luck getting one!], not the Ford 9'" chunk.
