This craziness has to stop.
At the end, it is not worth the extreme cost for marginal gains. First, unless they are Physical Vapor Deposition or Chromium Nitride coated, Titanium valves will wear at a faster rate than a SS valve. Although they have OEM applications such as the Corvette and many motorcycles makes, the valves they use are coated and they use valve seats with a higher Copper contents. Which means, if they are allowed, all seats will need to be replaced with a seat with a higher Copper contents. When NHRA allowed the use of Titanium valves on the 427 Fords, is due to the fact that at the time it was difficult to obtain hollow stem valves. Weight wise, the Titanium and hollow-stem valves are the same. Also, due to valve train dynamics, the RPM gains are not as much as many may believe. Today, you can buy good hollow stem SS valves from companies such as Ferrea. It also makes me wonder how many racers out there are using them. If the rule change is approved, I can see racers, later on, asking the valve stem size rule be deleted so they can run 7mm valve stems. |
#2 | |
Banned
This is not true I have been using ti valves since 1969 they was on Ford cast iron heads with no seat inserts the seat were not even Induction hardened at that time (they were released by Ford then for use in Tran's Am Boss 302 and 351 C), we used the first as Intakes as there was no Ti for Exhaust, it would not work according to TRW who was the first to supply. I have run the intakes till the margin was thin and started to chip (small V shapped cracks) we then took these valves and turned them down and made exhaust with a much thicker margin and lasted another couple years. I WOULD NOT be in favor of the change! Just trying to set the record straight. Quote:
Banned
If any one has the chance to buy New old stock the exhaust sodium filled pass on them as the sodium reacts to the steel and eats away from the inside out.
I recently held a 427 / 425 HP Ford intake valve from an old Hollman-Moody engine built in 1967 or so (the fishing boat engine I brought up on this forum). When disassembling the heads the head on an intake vale broke off. The dang thing was rifle drilled in the stem! Couldn't believe how light it was and it was a pretty large diameter valve. Now I know the exhaust are sodium filled on this engine but I didn't know they were doing this to intake valves back in the '60's. I'd have to say I'm with SS Engine guy and others on this. Based on my limited experience, I can't see the need. Sure it may be faster but I see no other benefit. Cost goes up, maintenance and replacement goes up and engine damage can be a real issue if one breaks. I lost two Stocker engines thanks to Mr. Schubeck, don't think I would want to go down this road.[/QUOTE] |
#4 | |
If you went back to the stock spring pressure in stock an awful lot of cars would slow down a bunch. And a lot of camshafts would become short pool cues.
Art Leong 2095 SS |
Banned
Liked 235 Times in 110 Posts
THAT would be a cost effective and smart move. No more Shubeck type lifters, no extream hi RPM's, "Ported" heads and intakes would become mostly obsolete, engines would last longer, building and maintaining a stocker would be less expensive, and less work. They dont HAVE to be stock pressures.....just an across the board maximum pressure would be fair for all combos. Todays stocker runs more spring pressure than my 1977-78 era Super Stocker and it would turn about 8000 RPM. No more square lobe cams.
Liked 216 Times in 7 Posts
I dont know if David is implying that I asked for this, but last year, after indy, I asked them to consider it. After I went to Jesel, and we got it to spin to 10,900 clean, with steel valves that weigh 148 grams, I didnt really care anymore. I think some of the facts in that letter are slightly skewed, I pay 50.00 a piece for custom ferrea valves, I can get Ti valves from CV for 100.00. I think that the spring life would double (50.00 ea) and that would pay the difference of the valves in about 30 runs. I think to say that 20 hemi customers havent broken a valve in 6 years is BS also, cause Daniels broke one at Vegas (Jim told me himself). We have all broke things in our racing careers, if you race, things break, and I am not ashamed to say I have tore up my share of parts. I dont really see why its a big deal. The motors cost 60K plus, whats another 400.00. MY customers by the way, are in favor of it. I hadnt heard a word about it until jeff K. told me at indy it was a done deal. I said whatever. Just let me know what the rules are, and I will figure out how to deal with them.
cw |
Liked 1,924 Times in 432 Posts
What about the rest of us who don't spend $60K on an engine, and don't need or want to?
I'd be okay with them making special rules for SS/AH, if that's what you guys want. At least some of the rest of us have no desire to add $1K to the cost of an engine, and cut the life of the engine by 50% to turn them 10K RPM.
Alan Roehrich 212A G/S |
#8 | |
Ed Wright 4156 SS/JA |
#9 | |
Liked 520 Times in 132 Posts
CW I have no issues with you on a personal level. Most of us don't have 60K engines that border on pro stock stuff. These added changes that keep coming up are going to run regular guys like myself outta here. It's a case of the have's once again gaining on the have nots. This is just my opinion whatever that's worth. LOL
#10 | |
Liked 203 Times in 52 Posts
Kevin |
