EVAN; Your comments on effect of altitude on a supercharged engines performance are correct, except that you forgot to mention the offsetting effect that helps to keep these cars faster at tracks such as Las Vegas. Since a blower takes HP to compress the ambient air, less dense air will lower the blower output pressure, but will also lower the Hp needed to compress it. The power needed to run a blower is significant, so the 'gain' from reduction in load is also significant.
Steve Last edited by Steve Hagberg; 10-31-2009 at 10:11 AM. Reason: spelling |
Liked 115 Times in 5 Posts
Steve,
Can I assume that you've measured the differences at different boost levels in order to report these findings? In theory you are right, but we are talking about small changes in boost level from good air to bad air. Probably 3-4 psi on the CJs from sea level to Vegas. The cost to drive the blower for that extra 3-4 psi is very, very small. I've tested over 100 blower cars with all types of blowers over the years and while I've not measured crank hp, save for one time on a 1,200 hp engine, I can tell you the loss in power from adding a few pounds of boost is not a lot. In that case it took upwards of 250 hp to run the blower. I would guess a change in boost, even at that level, would have very little effect on overall power loss/gain. Again, in theory you are right, but in practice the gain/loss is not what you think. Most blower engines are designed to run with boost pressure so even if you removed the blower it wouldn't give you a fair result on power because the engine would likely be inefficient with no boost. Evan
Evan Smith 1798 STK |
Liked 229 Times in 71 Posts
I was just wondering if anyone else noted the increments on Don Fezell's CJ in Richmond. To compare go to http://www.nhra.com/livetiming/livetiming.aspx and click on Race Archives. Find Virginia NHRA Nationals and click results. Compare Friday's Q1 increments to Sunday's R2 increments. They are pretty amazing!
#4 | |
Since it had already happened before, there was no excuse for it to happen again. Constant repetition of "it happened X years ago with Y cars" doesn't make it right for it to happen again with a different car or cars. What it does is either make NHRA look like fools for letting it happen again, or make us look like fools for letting NHRA do it to us again. I don't see any "other faults" that bogus race cars with under factored engines capable of running 2 seconds under their indexes are "soothing". They sure as Hell won't inspire NHRA to do anything with the AHFS, and in fact, it'll probably be just the opposite. They won't inspire anyone to build anything to race, either, except a few who have plenty of money and can afford to either buy these new "factory race cars" or build copies. Honestly, I can't see where this is so "good" for Stock or Super Stock. Did the entire class get anything out of it? No. We didn't get sudden national exposure in print, nor an increase in television time, either. There hasn't been any real increase in the purse or contingencies (for the most part, entry fees went up, and as a general rule, contingency payouts went down, while the purse remained the same as it has for years). We aren't treated any better by NHRA, either. I keep looking for all of this improvement these new cars are supposed to be bringing. It ain't happening.
Alan Roehrich 212A G/S |
#5 | |
Bill Seabrooks - superfan1 Bridgeport, Ct. |
#6 | |
The guys complaining about horsepower numbers must be GM guys.Take a 375hp,396,same specs as a 425hp,396,soooooo.Think of the many hp factors for basically the same 350 chevy engine.NHRA has always facrored according to who makes the most noise and who is their biggest sponsor at that time! JMO,got out of "stock" in the 70's when it was getting stupid! ROY.
#8 | |
If you flow the heads and intakes for those "basically the same" 350 engines, you'll find they are actually a bit different.
Liked 32 Times in 19 Posts
Guys many of you are missing the Point of the Mustangs. It got a factory to be interested in Drag racing again. NHRA wins. It got several more entries to events by guys seeing the bogus HP and jumping into them. NHRA wins. Everyone else keeps bringing their cars and racing NHRA wins. Many people talk about the injustice but are powerless to change it. NHRA at least breaks even....This is not about Fairness, it is not about racing, it is not about good factoring or intelligent thought related to the cars.... it is all about NHRA making money... Correctly done or poorly done... they continue to use the same thinking to do it..Our choices are continue to go and pay them entry, continue to complain of the unfairness and just race or..... Sad it kills the hobby many of us lived for...
Liked 229 Times in 99 Posts
The last of the cj's is gone. Ran dead on with a 0 and still lost.
I guess all that extra horsepower didn't help.
Floyd Staggs 787 SST |
