Old 03-26-2009, 09:12 PM   #1
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Default Re: We need a new "instant" trigger!
Y'all are missing the point. Bob Shaw built that car, knowing it was going to be real heavy for "U". He can't run V anyway.It's a V8 .
I'm sure he doesn't have a weight box either. What do you want to tell him? He can't race?
If the car is 400 heavy with no ballast , the hp % is irrelevant, or atleast off the charts.
If that's the case then if Tech can verify that the car is that heavy without ballast then I dont see a problem with an exclusion for that combo.I dont think many cars fit into that scenario.That would also be a good time to try and put a more realistic HP # on that combo.
Ed F.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 03-26-2009, 11:46 AM   #2
Mike Carr
Mike Carr's Avatar
Liked 83 Times in 37 Posts
Ok, now I see what you mean, and what you want to do. By "trigger", I thought you were referring to the -1.40 under mark. At 3.25%, an A/SA 427/425 would get hit 14 HP. Bob's car, at 180 HP in U/SA, gets hit only six. Which, on the surface, doesn't seem fair. Yet, the the U/SA gets more weight added (120 pounds vs the A/SA's 112 pounds). At 4%, it would be 18 HP and 144 pounds in A/SA and 8 HP and 160 pounds in U/SA. 5% is 22 HP and 176 pounds in A, 9 HP and 180 pounds in U. I suppose if one were to want to increase the rate at which a combination receives HP, they would go for a higher percentage (4 or 5%). Would that be too much or not enough? You might poll 100 racers and get 75-80 different opinions and responses. Maybe we need a poll posted on here to see what other's opinions and thoughts are. ME personally, again, I wouldn't change much. They could always make a small change, maybe up to 3.5% and see what that does. BTW, did you get your book in the mail, Billy?
Old 03-26-2009, 11:51 AM   #3
Billy Nees
Liked 7,909 Times in 1,754 Posts
Mike, yes I did and I'm sorry for not thanking you sooner.
Billy Nees 1188 STK, SS
Billy Nees is online now   Reply With Quote
Old 03-26-2009, 11:53 AM   #4
Billy Nees
Mark, you're right but it would help to bring it in line twice as soon without obsoleteing a combo overnight.
Old 03-26-2009, 12:06 PM   #5
Question Re: We need a new "instant" trigger!
Billy-- Using your 7% would be harsh at best -- for example our LS1 Firebird is rated at 364 hp -- 7% would be 25 HP at one shot -- or in C/SA trim-- a 9lb class-- thats 225 lbs at one time -- ouch ! ! ! One fabulous day at Atco or somewhere with good air and your toast -- no thanks ! ! ! You're trying to reinvent the wheel in a day .......
Old 03-26-2009, 12:10 PM   #6
Liked 5,153 Times in 1,967 Posts
Maybe I'm taking this thread o/t, but here's some ideas for getting some of the soft hp ratings in line:
(I'm not advocating any of them. Just tossing them out)
Implement the AHFS adjustments 4 times a year.
Take away the "free race " during the data period.
Include altitude tracks in the 1.15 and 1.40 trigger (under the factored index)
Lower the "high side " trigger to 1.30 under.
Trouble is , if you implement all the above, you'll have alot more racers making 1000 ' runs in qualifying, and "bracket racing" in class and heads- up runs.
Not good , if you ever want to build spectator appeal for S/SS
Old 03-26-2009, 12:13 PM   #7
art leong
Mike, maybe I didn't make myself clear. I'm OK with the -1.40 number I just don't think that the 3.25% number is enough. What I'm looking for is something like 7% or even more.
Billy maybe they should institute the "Artie Leong" rule 8.5% in one shot. Seemed to make a lot of people happy at the time.
Lets see now? 425 HP times 8.5%. Thats 36 horsepower in a 9 pound class thats 320 pounds. Sounds like a plan to me.
To be serious. Billy whatever the number guys are still going to play games. And run in braket mode. I just think anyone the goes fast enough for a instant hit sound be torn down. And nhra should use corrected density altitude. For their books We all know running 115 under in a mineshaft is easier than running 115 under at 3000' density altitude.
Art Leong 2095 SS
Old 03-26-2009, 12:34 PM   #8
Chad Rhodes
how about this.
1.400-1.424 under = 3.5%
1.425-1.449 under = 5%
1.450-1.474 under = 7%
1.475 under or more = 10%
or 1% for every .01 under 1.40
Chad Rhodes 2113 I/SA
Old 03-26-2009, 12:54 PM   #9
novassdude
Liked 136 Times in 49 Posts
I think Chad is on to the right idea. Make it multiple trigger points each with a larger hit on the horse power. I would maybe spread ot out alittle more that what he had. Maybe an extra percent per tenth or some thing like that.
In the case of some thing like a 2:00 under run it should be hit no matter where the run takes place. weather it was a factord track or not.
novassdude is offline   Reply With Quote
Old 03-26-2009, 12:55 PM   #10
Billy Nees
Jack, OK 25 HP in one shot instead of 2 or 3 shots. 225 lbs will slow your LS-1 down what? 1.8 tenths? Your still 1.22 under. You aren't getting any sympathy here pal.
Art, I still remember being there on that day and I don't remember you getting any sympathy from Jack but t
hen you were in one of those oddball, slow cars and not an LS-1 Firebird.
Chad, something like that might wirk but lower the trigger to -1.35.
