Why aluminum and not plastic fuel cell.
Liked 5 Times in 3 Posts
Once alum is bolted down it's grounded. Also a plastic cell over the years of setting in a hot trunk will start to loose it's shape as the heat & pressure from the hold-down straps wear on it. Oh & alum looks PRETTY!
Less chance of condensation with a plastic cell.....I have a 5 gallon RCI.
"Despite the high cost of living, it remains popular." Dave Cook NHRA N375 |
What ever your choice is, I prefer aluminum, make sure to remove the foam
Bill Belden Retired Stock Eliminator [emailSTK1100@comcast.net[/email] |
#5 | |
I agree with aluminum over plastic but I still have the original foam in my Triangle engineering 5 gallon cell for 5 years now with no problem, only running race gas though.. I think the cheaper cells have foam issues. JMO.... bob |
Liked 4 Times in 4 Posts
i ordered a 5 gallon aluminum, thanks guys
There's no need for foam unless you run roundy round. Just keep the cell full and there's no slosh. If you ever get fuel that won't check you'll be digging the foam out at the track anyway to get rid of the bad stuff trapped in the foam.
John Mason 7743 SS |
are you using the tabs to mount it or are you using straps also. thanks
